Je possede un thermostat Netatmo et j’aimerais que quand on mets en chauffe ou en off depuis le thermostat la chaudiere ca fasse basculer mon input.booleen.chaudiere qui lui a deja une action de off et on
Voici mon thermostat
hvac_modes:
- auto
- heat
- 'off'
min_temp: 7
max_temp: 35
target_temp_step: 0.5
preset_modes:
- away
- boost
- Frost Guard
- Schedule
current_temperature: 20.8
temperature: 19
hvac_action: idle
preset_mode: Schedule
battery_level: 100
selected_schedule: 5fcf919e22805174495eefa1
friendly_name: Netatmo Thermostat Generale
supported_features: 17
voici mon automatisation du input qui a deja une action on et off sur la chaudiere
alias: Chaudiere off/on
description: ''
- platform: state
entity_id: input_boolean.chaudiere
to: 'on'
condition:
- condition: state
entity_id: climate.netatmo_thermostat_generale
state: idle
attribute: hvac_action
- service: climate.set_hvac_mode
hvac_mode: auto
entity_id:
- climate.netatmo_thermostat_generale
alias: Chaudiere On/Off
description: ''
- platform: state
to: 'off'
condition:
- condition: state
state: idle
- device_id: 81e9c7da9c1d72fe16649a7cbbf1ef07
domain: climate
entity_id: climate.netatmo_smart_thermostat
type: set_hvac_mode
hvac_mode: 'off'
et voici mon automatisation que j’essaie de mettre en place quand madame coupe la chaudiere depuis le thermostat.
alias: en cours input chaudiere etat climate off
description: ''
- platform: state
attribute: hvac_modes
to: 'off'
condition:
- condition: state
state: 'on'
Merci pour vos conseils de pros
System Health
version | core-2021.3.2 |
installation_type | Home Assistant Supervised |
dev | false |
hassio | true |
docker | true |
virtualenv | false |
python_version | 3.8.7 |
os_name | Linux |
os_version | 4.19.0-16-amd64 |
arch | x86_64 |
timezone | Europe/Paris |
GitHub API | ok |
Github API Calls Remaining | 4634 |
Installed Version | 1.11.3 |
Stage | running |
Available Repositories | 779 |
Installed Repositories | 52 |
logged_in | false |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | ok |
Hass.io
host_os | Debian GNU/Linux 10 (buster) |
update_channel | stable |
supervisor_version | supervisor-2021.03.9 |
docker_version | 20.10.5 |
disk_total | 113.6 GB |
disk_used | 9.7 GB |
healthy | true |
supported | true |
supervisor_api | ok |
version_api | ok |
installed_addons | Samba share (9.3.1), Duck DNS (1.12.5), MQTT Server & Web client (1.2.0), File editor (5.2.0), Terminal & SSH (9.1.0), ESPHome (1.16.2), Spotify Connect (0.8.2), InfluxDB (4.0.4), Grafana (6.2.0), Portainer (1.4.0), Node-RED (8.2.1), Tydom2MQTT - Beta (release_1.01), Zigbee2mqtt (1.18.2-1), Zigbee2mqtt Edge (edge), Home Assistant Google Drive Backup (0.103.1) |
Lovelace
dashboards | 1 |
resources | 33 |
views | 12 |
mode | storage |
Spotify
api_endpoint_reachable | ok |
