Bonjour a tous
Voila j ai message erreur avec l integration netatmo le bouton de lumiere ne fonctionne pas et je pense que c est lié au webhook :
Logger: homeassistant.components.netatmo
Source: components/netatmo/init.py:189
Integration: Netatmo (documentation, issues)
First occurred: 19:01:32 (1 occurrences)
Last logged: 19:01:32
Error during webhook registration - 400 - Bad request - Allowed ports for webhooks are 80, 88, 443 and 9443. (21) when accessing ‹ https://api.netatmo.com/api/addwebhook ›
je ne comprends pas comment réinitialiser les webhook
dans la doc il y a ceci
mais je ne vois pas ou sur la page developer je peux le faire
es ce que vous pouvez m aider SVP
Merci Jim
[center]## System Health
version | core-2021.4.4 |
dev | false |
hassio | true |
docker | true |
virtualenv | false |
python_version | 3.8.7 |
os_name | Linux |
os_version | 5.4.83-v8 |
arch | aarch64 |
timezone | Europe/Paris |
GitHub API | ok |
Github API Calls Remaining | 5000 |
Installed Version | 1.11.3 |
Stage | running |
Available Repositories | 776 |
Installed Repositories | 10 |
host_os | Home Assistant OS 5.13 |
update_channel | stable |
supervisor_version | supervisor-2021.04.0 |
docker_version | 19.03.15 |
disk_total | 57.8 GB |
disk_used | 28.6 GB |
healthy | true |
supported | true |
board | rpi4-64 |
supervisor_api | ok |
version_api | ok |
installed_addons | File editor (5.2.0), Samba share (9.3.1), Terminal & SSH (9.0.2), Home Assistant Google Drive Backup (0.103.1), Mosquitto broker (5.1.1), Grafana (6.2.0), InfluxDB (4.0.3), Duck DNS (1.12.5), CEC Scanner (2.4), ESPHome (dev) (dev), MQTT Server & Web client (1.2.0), Visual Studio Code (3.1.1) |
Lovelace
dashboards | 1 |
resources | 4 |
views | 8 |
mode | storage |
