Bonjour a tous,
Je pofine mon neoud sur node red est j’ai une valeur de ma temperature qui passe par un input.number qui genere un msg.payload et cette valeur je veux lui retirer 1 car j’ai trois radiateur mais je veux qu’un des radiateur la temperature soi de -1 du msg.payload
voici ma data du noeud
"temperature": msg.payload
et voici le debug du noeud
{"payload":"19.0","data":{"entity_id":"input_boolean.confort","state":"on","attributes":{"editable":true,"icon":"mdi:white-balance-sunny","friendly_name":"confort"},"last_changed":"2022-01-22T12:20:34.730568+00:00","last_updated":"2022-01-22T12:20:34.730568+00:00","context":{"id":"bbdbc0389f9fdf2046ca0e8085aa59a9","parent_id":null,"user_id":"612f5c285a564071a6ab8b55938af833"},"timeSinceChangedMs":228,"original_state":"on"},"topic":"inputconfort","_msgid":"8c3ea0d3a02facc9"}
Merci pour votre aide.
System Health
version | core-2021.12.10 |
installation_type | Home Assistant Supervised |
dev | false |
hassio | true |
docker | true |
user | root |
virtualenv | false |
python_version | 3.9.7 |
os_name | Linux |
os_version | 4.19.0-17-amd64 |
arch | x86_64 |
timezone | Europe/Paris |
GitHub API | ok |
Github API Calls Remaining | 4686 |
Installed Version | 1.19.3 |
Stage | running |
Available Repositories | 947 |
Downloaded Repositories | 69 |
AccuWeather
can_reach_server | ok |
remaining_requests | 29 |
logged_in | false |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | ok |
host_os | Debian GNU/Linux 10 (buster) |
update_channel | beta |
supervisor_version | supervisor-2021.12.2 |
docker_version | 20.10.8 |
disk_total | 113.6 GB |
disk_used | 21.2 GB |
healthy | true |
supported | failed to load: Unsupported |
supervisor_api | ok |
version_api | ok |
installed_addons | Samba share (9.5.1), MQTT Server & Web client (1.2.0), Terminal & SSH (9.3.0), Spotify Connect (0.10.0), Grafana (7.4.1), Tydom2MQTT - Beta (release_v1.2.4), InfluxDB (4.3.0), Glances (0.14.2), Dnsmasq (1.4.4), Duck DNS (1.14.0), Studio Code Server (4.1.0), File editor (5.3.3), Zigbee2mqtt (1.22.2-1), Zigbee2mqtt Edge (edge), ESPHome (2022.1.1), Node-RED (10.3.4) |
Lovelace
dashboards | 3 |
resources | 45 |
views | 17 |
mode | storage |
Spotify
api_endpoint_reachable | ok |
