Node-RED, utiliser des variables globales dans les flows?
Voici comment stocker et utiliser les variables sur le call service.
[{"id":"27b143e62c23b87e","type":"tab","label":"Flow 2","disabled":false,"info":"","env":[]},{"id":"2716efc8116066eb","type":"inject","z":"27b143e62c23b87e","name":"255, 0, 0","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"255, 0, 0","payloadType":"str","x":160,"y":100,"wires":[["4eea63b6063cb7f1"]]},{"id":"4eea63b6063cb7f1","type":"change","z":"27b143e62c23b87e","name":"rouge","rules":[{"t":"set","p":"rouge","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":430,"y":100,"wires":[[]]},{"id":"fa3b006756e11303","type":"inject","z":"27b143e62c23b87e","name":"0, 255, 0","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"0, 255, 0","payloadType":"str","x":160,"y":140,"wires":[["3041cffa38cb43b2"]]},{"id":"3041cffa38cb43b2","type":"change","z":"27b143e62c23b87e","name":"vert","rules":[{"t":"set","p":"vert","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":430,"y":140,"wires":[[]]},{"id":"3f069c3b2375f8b3","type":"inject","z":"27b143e62c23b87e","name":"0, 0, 255","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"0, 0, 255","payloadType":"str","x":160,"y":180,"wires":[["067f64453bebbfa2"]]},{"id":"067f64453bebbfa2","type":"change","z":"27b143e62c23b87e","name":"bleu","rules":[{"t":"set","p":"bleu","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":430,"y":180,"wires":[[]]},{"id":"5e85c25b0d0c6ccf","type":"inject","z":"27b143e62c23b87e","name":"rouge","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":170,"y":340,"wires":[["abf3cc4dd1e4e6cf"]]},{"id":"fa1d0568910f15d9","type":"api-call-service","z":"27b143e62c23b87e","name":"salon","server":"df03acce.f940b","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":["5ffdd31f3543429c5253c8747b38389e"],"entityId":[],"data":"{\"rgb_color\":[{{payload}}]}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":570,"y":400,"wires":[[]]},{"id":"abf3cc4dd1e4e6cf","type":"change","z":"27b143e62c23b87e","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"rouge","tot":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":340,"wires":[["fa1d0568910f15d9"]]},{"id":"d3274e5df8f78034","type":"inject","z":"27b143e62c23b87e","name":"vert","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":170,"y":400,"wires":[["c4b3574d753848a4"]]},{"id":"c4b3574d753848a4","type":"change","z":"27b143e62c23b87e","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"vert","tot":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":400,"wires":[["fa1d0568910f15d9"]]},{"id":"c4a922913263d59e","type":"inject","z":"27b143e62c23b87e","name":"bleu","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":170,"y":460,"wires":[["c1cf511e84f06569"]]},{"id":"c1cf511e84f06569","type":"change","z":"27b143e62c23b87e","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"bleu","tot":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":460,"wires":[["fa1d0568910f15d9"]]},{"id":"c80b1def3143c50f","type":"comment","z":"27b143e62c23b87e","name":"Définition des variables","info":"","x":180,"y":40,"wires":[]},{"id":"9ca957228f784d63","type":"comment","z":"27b143e62c23b87e","name":"couleurs en fonction des variables","info":"","x":220,"y":300,"wires":[]},{"id":"df03acce.f940b","type":"server","name":"Home Assistant","version":2,"addon":false,"rejectUnauthorizedCerts":false,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30"}]
