Par exemple comme ça, à adapter…
[{"id":"b9e21c24a8b4de6e","type":"api-current-state","z":"671609705841dfab","name":"","server":"d28c9492.f419c8","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.armed_away","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":580,"y":1040,"wires":[["05310418c5759b1d"]]},{"id":"724ccf7906a633ce","type":"inject","z":"671609705841dfab","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":300,"y":1040,"wires":[["b9e21c24a8b4de6e"]]},{"id":"05310418c5759b1d","type":"change","z":"671609705841dfab","name":"","rules":[{"t":"set","p":"etat","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":860,"y":1040,"wires":[[]]},{"id":"2aae3113ab6e95a0","type":"inject","z":"671609705841dfab","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":320,"y":1120,"wires":[["a643e97e37b4c296"]]},{"id":"a4a05ac7488a460e","type":"switch","z":"671609705841dfab","name":"","property":"etat","propertyType":"flow","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":630,"y":1120,"wires":[["8958142687e8106a"],["e4844e4cb0a2c089"]]},{"id":"e4844e4cb0a2c089","type":"debug","z":"671609705841dfab","name":"debug 133","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"$flowContext(\"etat\")","targetType":"jsonata","statusVal":"","statusType":"auto","x":830,"y":1160,"wires":[]},{"id":"8958142687e8106a","type":"debug","z":"671609705841dfab","name":"debug 134","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":830,"y":1100,"wires":[]},{"id":"a643e97e37b4c296","type":"change","z":"671609705841dfab","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"Un autre message","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":480,"y":1120,"wires":[["a4a05ac7488a460e"]]},{"id":"d28c9492.f419c8","type":"server","name":"hassio","version":5,"addon":false,"rejectUnauthorizedCerts":false,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
