Renseigner votre problème
j’ai cree cette demande de notification et je ne recois rien.
Mais quand je fais un teste cela fonction.
Je suis perdu help please.
utilisation ESP82 SDS011 DHT22
alias: Notif qualite air
description: « »
trigger: []
condition:
- or:
- condition: numeric_state
entity_id: sensor.particulate_2_5um
above: 12 - condition: numeric_state
entity_id: sensor.particulate_10_0um
above: 40
- device_id: 3f0856dafe70659251bd73a3df89fe36
domain: mobile_app
type: notify
message: Attention Masque
title: Attention particule
Dans votre HA, Menu latéral
Paramètres
> Système
> Corrections
puis une fois en bas Copier
version | core-2022.10.3 |
dev | false |
hassio | true |
docker | true |
user | root |
virtualenv | false |
python_version | 3.10.5 |
os_name | Linux |
os_version | 5.15.61-v8 |
arch | aarch64 |
timezone | Europe/Dublin |
config_dir | /config |
GitHub API | ok |
GitHub Content | ok |
GitHub Web | ok |
GitHub API Calls Remaining | 5000 |
Installed Version | 1.28.0 |
Stage | running |
Available Repositories | 1187 |
Downloaded Repositories | 11 |
logged_in | false |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | ok |
host_os | Home Assistant OS 9.2 |
update_channel | stable |
supervisor_version | supervisor-2022.10.0 |
agent_version | 1.4.1 |
docker_version | 20.10.17 |
disk_total | 28.5 GB |
disk_used | 5.9 GB |
healthy | true |
supported | true |
board | rpi4-64 |
supervisor_api | ok |
version_api | ok |
installed_addons | File editor (5.4.1), Samba share (10.0.0), Duck DNS (1.15.0), ESPHome (2022.9.4), AirCast (3.4.1), Terminal & SSH (9.6.1), AdGuard Home (4.7.4), Example (5.1.1), MQTT IO (0.1.3), Node-RED (13.4.0) |
dashboards | 1 |
resources | 4 |
views | 1 |
mode | storage |
oldest_recorder_run | 3 octobre 2022 à 11:50 |
current_recorder_run | 11 octobre 2022 à 19:08 |
estimated_db_size | 334.04 MiB |
database_engine | sqlite |
database_version | 3.38.5 |
