j’ai un NVR dahua (nvr2104P) ou j’ai dessus 3 cameras. 2 en filaire et une en wifi.
sur la page du nvr adresse ip . je voit bien mes cameras.
j’ai essayer l integration dahua mais sans succes, adresse ou mot de passe ou utilisateur invalide.
Mon HA tourne sous un mini pc
comment pourrais je recuperer mes 3 cameras??
Merci d’avance
| version |
core-2025.5.3 |
| installation_type |
Home Assistant OS |
| dev |
false |
| hassio |
true |
| docker |
true |
| user |
root |
| virtualenv |
false |
| python_version |
3.13.3 |
| os_name |
Linux |
| os_version |
6.12.23-haos |
| arch |
x86_64 |
| timezone |
Europe/Paris |
| config_dir |
/config |
| GitHub API |
ok |
| GitHub Content |
ok |
| GitHub Web |
ok |
| HACS Data |
ok |
4994 |
| Installed Version |
2.0.6-dev-df50f45 |
| Stage |
running |
| Available Repositories |
2080 |
| Downloaded Repositories |
20 |
| logged_in |
true |
| subscription_expiration |
15 janvier 2026 à 01:00 |
| relayer_connected |
true |
| relayer_region |
eu-central-1 |
| remote_enabled |
true |
| remote_connected |
true |
| alexa_enabled |
false |
| google_enabled |
true |
| cloud_ice_servers_enabled |
true |
| remote_server |
eu-central-1-23.ui.nabu.casa |
| certificate_status |
ready |
| instance_id |
dfab76ffd5974d91a5f7a38d0c788870 |
| can_reach_cert_server |
ok |
| can_reach_cloud_auth |
ok |
| can_reach_cloud |
ok |
| host_os |
Home Assistant OS 15.2 |
| update_channel |
stable |
| supervisor_version |
supervisor-2025.05.3 |
| agent_version |
1.7.2 |
| docker_version |
28.0.4 |
| disk_total |
234.0 GB |
| disk_used |
9.2 GB |
| healthy |
true |
| supported |
true |
| host_connectivity |
true |
| supervisor_connectivity |
true |
| ntp_synchronized |
true |
| virtualization |
| board |
generic-x86-64 |
| supervisor_api |
ok |
| version_api |
ok |
| installed_addons |
Get HACS (1.3.1), Z-Wave JS UI (4.4.0), Z-Wave JS (0.13.1), Samba share (12.5.1), Silicon Labs Multiprotocol (2.4.5), File editor (5.8.0), NGINX Home Assistant SSL proxy (3.11.1), Mosquitto broker (6.5.1), Zigbee2MQTT (2.4.0-1), Studio Code Server (5.19.3) |
| dashboards |
3 |
| resources |
17 |
| views |
3 |
| mode |
storage |
Network Configuration
| adapters |
lo (disabled), enp2s0 (enabled, default, auto), hassio (disabled), docker0 (disabled), vethf7b7865 (disabled), veth1840c74 (disabled), vethb96d80f (disabled), vethab79fd8 (disabled), veth7fc4b43 (disabled), veth4278281 (disabled), veth96bd7b5 (disabled), veth0ff8c91 (disabled), veth12a893d (disabled) |
| ipv4_addresses |
lo (127.0.0.1/8), enp2s0 (192.168.1.198/24), hassio (172.30.32.1/23), docker0 (172.30.232.1/23), vethf7b7865 (), veth1840c74 (), vethb96d80f (), vethab79fd8 (), veth7fc4b43 (), veth4278281 (), veth96bd7b5 (), veth0ff8c91 (), veth12a893d () |
| ipv6_addresses |
lo (::1/128), enp2s0 (2a01:e0a:e2e:74b0:23c0:f6b0:3fa3:efc5/64, fe80::3b94:ef0e:8e64:eb09/64), hassio (fe80::e8ed:85ff:fe19:ec5/64), docker0 (fe80::3887:dbff:fea4:edc7/64), vethf7b7865 (fe80::18e6:3cff:fef0:9662/64), veth1840c74 (fe80::50d6:84ff:fe06:8862/64), vethb96d80f (fe80::74a0:69ff:fe0b:2055/64), vethab79fd8 (fe80::9c82:caff:fed7:4998/64), veth7fc4b43 (fe80::a056:f2ff:fe0a:9b45/64), veth4278281 (fe80::f898:9dff:fe77:1d75/64), veth96bd7b5 (fe80::d417:2cff:fe66:1b13/64), veth0ff8c91 (fe80::4dd:a5ff:fe59:72c9/64), veth12a893d (fe80::dccb:efff:fee5:68a7/64) |
| announce_addresses |
192.168.1.198, 2a01:e0a:e2e:74b0:23c0:f6b0:3fa3:efc5, fe80::3b94:ef0e:8e64:eb09 |
| oldest_recorder_run |
30 mai 2025 à 11:25 |
| current_recorder_run |
10 juin 2025 à 08:31 |
| estimated_db_size |
639.36 MiB |
| database_engine |
sqlite |
| database_version |
3.48.0 |
Sonoff
| version |
3.8.1 (ffa7e22) |
| cloud_online |
1 / 1 |
| local_online |
1 / 1 |
system
A fermé ce sujet ()
2
