Obliger de redémarrer manuellement Zigbee2mqtt
Hello tout le monde,
Depuis ce soir, je ne sais pas pourquoi, je dois redémarrer automatiquement zigbee2mqtt manuellement toutes les 5 minutes… J’ai beau être revenu à une version différente, mais rien ne change, je ne comprends pas… Voici les logs.
[2026-03-03 19:47:48] error: 	zh:ember:uart:ash: Port Error: read ECONNRESET
[2026-03-03 19:47:48] info: 	zh:ember:uart:ash: Port closed, error=true
[2026-03-03 19:47:48] error: 	zh:ember:ezsp: Fatal error, status=ERROR_SERIAL_INIT. Last Frame: [FRAME: ID=52:"SEND_UNICAST" Seq=69 Len=10]
[2026-03-03 19:47:48] info: 	zh:ember:uart:ash: ASH COUNTERS since last clear:
[2026-03-03 19:47:48] info: 	zh:ember:uart:ash:   Total frames: RX=214, TX=285
[2026-03-03 19:47:48] info: 	zh:ember:uart:ash:   Cancelled   : RX=0, TX=0
[2026-03-03 19:47:48] info: 	zh:ember:uart:ash:   DATA frames : RX=213, TX=70
[2026-03-03 19:47:48] info: 	zh:ember:uart:ash:   DATA bytes  : RX=6285, TX=1343
[2026-03-03 19:47:48] info: 	zh:ember:uart:ash:   Retry frames: RX=0, TX=0
[2026-03-03 19:47:48] info: 	zh:ember:uart:ash:   ACK frames  : RX=0, TX=214
[2026-03-03 19:47:48] info: 	zh:ember:uart:ash:   NAK frames  : RX=0, TX=0
[2026-03-03 19:47:48] info: 	zh:ember:uart:ash:   nRdy frames : RX=0, TX=0
[2026-03-03 19:47:48] info: 	zh:ember:uart:ash:   CRC errors      : RX=0
[2026-03-03 19:47:48] info: 	zh:ember:uart:ash:   Comm errors     : RX=0
[2026-03-03 19:47:48] info: 	zh:ember:uart:ash:   Length < minimum: RX=0
[2026-03-03 19:47:48] info: 	zh:ember:uart:ash:   Length > maximum: RX=0
[2026-03-03 19:47:48] info: 	zh:ember:uart:ash:   Bad controls    : RX=0
[2026-03-03 19:47:48] info: 	zh:ember:uart:ash:   Bad lengths     : RX=0
[2026-03-03 19:47:48] info: 	zh:ember:uart:ash:   Bad ACK numbers : RX=0
[2026-03-03 19:47:48] info: 	zh:ember:uart:ash:   Out of buffers  : RX=0
[2026-03-03 19:47:48] info: 	zh:ember:uart:ash:   Retry dupes     : RX=0
[2026-03-03 19:47:48] info: 	zh:ember:uart:ash:   Out of sequence : RX=0
[2026-03-03 19:47:48] info: 	zh:ember:uart:ash:   ACK timeouts    : RX=0
[2026-03-03 19:47:48] info: 	zh:ember:uart:ash: ======== ASH stopped ========
[2026-03-03 19:47:48] info: 	zh:ember:ezsp: ======== EZSP stopped ========
[2026-03-03 19:47:48] info: 	zh:ember: ======== Ember Adapter Stopped ========
[2026-03-03 19:47:48] error: 	z2m: Adapter disconnected, stopping
[2026-03-03 19:47:48] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"offline"}'
[2026-03-03 19:47:48] info: 	z2m: Disconnecting from MQTT server
[2026-03-03 19:47:48] info: 	z2m: Stopping zigbee-herdsman...
[2026-03-03 19:47:48] info: 	z2m: Stopped zigbee-herdsman
[2026-03-03 19:47:48] info: 	z2m: Stopped Zigbee2MQTT
Cela veut dire quoi, que ma clé SMILIGHT se déconnecte ?
Merci pour l’aide :slight_smile:
version core-2026.2.3
container_arch amd64
python_version 3.13.11
os_version 6.12.67-haos
arch x86_64
GitHub API Calls Remaining 4996
Installed Version 2.0.5
Available Repositories 2802
Downloaded Repositories 29
host_os Home Assistant OS 17.1
supervisor_version supervisor-2026.02.3
agent_version 1.8.1
docker_version 29.1.3
disk_total 30.8 GB
disk_used 14.3 GB
nameservers 89.2.0.1, 89.2.0.2
virtualization kvm
board ova
installed_addons Duck DNS (1.26.0), ESPHome Device Builder (2026.2.2), Whisper (3.1.0), Studio Code Server (6.0.1), Linky (1.7.0), File editor (5.8.0), Piper (2.2.2), Mosquitto broker (6.5.2), openWakeWord (2.1.0), Zigbee2MQTT (2.8.0-1), Terminal & SSH (10.0.1)
dashboards 7
resources 25
error /config/ui-lovelace.yaml not found
views 5
Network Configuration
adapters lo (disabled), enp0s3 (enabled, default, auto), hassio (disabled), docker0 (disabled), veth910dd7c (disabled), veth0f2a406 (disabled), veth134f0e4 (disabled), vethcfe26e6 (disabled), vethf843749 (disabled), vethc0e51b5 (disabled), veth8147a79 (disabled), vethfa6324f (disabled), veth938ab22 (disabled), vethbd04f53 (disabled), vetha1eaec7 (disabled), veth20dd6d3 (disabled), vethedc2e88 (disabled), veth1748e77 (disabled), vethc231358 (disabled)
ipv4_addresses lo (127.0.0.1/8), enp0s3 (192.168.0.34/24), hassio (172.30.32.1/23), docker0 (172.30.232.1/23), veth910dd7c (), veth0f2a406 (), veth134f0e4 (), vethcfe26e6 (), vethf843749 (), vethc0e51b5 (), veth8147a79 (), vethfa6324f (), veth938ab22 (), vethbd04f53 (), vetha1eaec7 (), veth20dd6d3 (), vethedc2e88 (), veth1748e77 (), vethc231358 ()
ipv6_addresses lo (::1/128), enp0s3 (fe80::f55c:338f:3b73:5086/64), hassio (fd0c:ac1e:2100::1/48, fe80::1c31:f3ff:fef6:5a28/64), docker0 (fe80::543a:6aff:fe6a:8a80/64), veth910dd7c (fe80::78c1:c2ff:feff:ff3e/64), veth0f2a406 (fe80::fc40:41ff:feb0:74d5/64), veth134f0e4 (fe80::e886:d3ff:fed5:e8ac/64), vethcfe26e6 (fe80::e012:3bff:fec7:140c/64), vethf843749 (fe80::fc10:13ff:fe15:b4d8/64), vethc0e51b5 (fe80::50b3:9dff:fe4f:1d9f/64), veth8147a79 (fe80::3c7c:2ff:feb6:f680/64), vethfa6324f (fe80::f4d6:6cff:fec3:2e9e/64), veth938ab22 (fe80::189c:7eff:fea6:f807/64), vethbd04f53 (fe80::7c5b:1cff:fea5:47df/64), vetha1eaec7 (fe80::d887:beff:fe6c:e2ea/64), veth20dd6d3 (fe80::f457:c8ff:fee1:6441/64), vethedc2e88 (fe80::14b6:b7ff:fe7f:71c3/64), veth1748e77 (fe80::3c3d:13ff:fe5b:7137/64), vethc231358 (fe80::5444:a1ff:fee5:20d/64)
announce_addresses 192.168.0.34, fe80::f55c:338f:3b73:5086
oldest_recorder_run 18 février 2026 à 20:21
current_recorder_run 3 mars 2026 à 19:33
estimated_db_size 1252.92 MiB
database_version 3.49.2
c’est quoi comme clé ?
Les ports USB sont bien alimentés? (tu n’as pas d’autres appareils USB?)
c’est quoi comme machine?
Tu as pas ZHA qui est revenu dans tes intégration ?
Ce genre de problème c’est souvent soit un problème d’alimentation ou un problème d’accès à la clef.
Une SMLIGHT pardon… branchée en PoE. HA tourne sur une VM sur mon NAS Ugreen.
Non je n’utilise pas ZHA mais z2m.
Smlight fait aussi des clés USB, et comme ton log ne permet pas à coup sûr de savoir si c’était une USB ou Ethernet… pas fafile de répondre…
Bref du coup, est-ce qu’il y a des traces dans les logs sur l’interface de la clé… ?
C’est la marque, mais tu ne dit pas le modèle exacte.
Tu ne l’utilise pas mais est il bien ignoré dans les intégration, jette un coup d’oeil.
Tu as quoi comme autre clef sur ta machine ?
Sorry, c’est la SLZB-06M.
Après avoir éteint / rallumé ma box SFR, débranché / rebranché la SMLIGHT, tout est rentré dans l’ordre. L’informatique…
Donc c’est une périphérique réseau
Tu as bien fixé son ip (manuellement ou via DHCP) ? tu as pensé à vérifier que ton smlight répond 1 des simple commandes réseau comme un ping ?
En partant du postulat qu’il est branché en réseau et pas en usb
Oui oui il est bien branché en réseau. Ola ça je ne sais plus, je regarde ce soir quand je rentre chez moi.
