Je ne connais pas tous les nœuds et astuces de Node Red, mais j’avance tranquillement…
Quelle serait selon vous la meilleure façon d’optimiser ce flux qui demande à chaque fois de connaître l’état de l’alarme ?
Merci pour vos conseils,
[{"id":"1da58cc48ab1b4d1","type":"inject","z":"afd5deb31ca9e1cd","name":"Start 6:00","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"00 06 * * *","once":false,"onceDelay":0.1,"topic":"","payload":"off","payloadType":"str","x":830,"y":120,"wires":[["94b67e7f40ed4bc2"]]},{"id":"b37b4825f8d9db81","type":"api-call-service","z":"afd5deb31ca9e1cd","name":"Ouvrir VR 1","server":"f1388c55.bbcd1","version":5,"debugenabled":false,"domain":"cover","service":"open_cover","areaId":[],"deviceId":[],"entityId":[],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1270,"y":120,"wires":[[]]},{"id":"94b67e7f40ed4bc2","type":"api-current-state","z":"afd5deb31ca9e1cd","name":"Alarme ON","server":"f1388c55.bbcd1","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.groupe_1_ss","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1050,"y":120,"wires":[[],["b37b4825f8d9db81","4088c166b58896cb"]]},{"id":"cc5bdd191ec4afd8","type":"inject","z":"afd5deb31ca9e1cd","name":"Start 7:00","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"00 07 * * *","once":false,"onceDelay":0.1,"topic":"","payload":"off","payloadType":"str","x":830,"y":180,"wires":[["ee5678f4787175d8"]]},{"id":"ee5678f4787175d8","type":"api-current-state","z":"afd5deb31ca9e1cd","name":"Alarme ON","server":"f1388c55.bbcd1","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.groupe_1_ss","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1050,"y":180,"wires":[[],["a3ea742f50e691ad","dcfc8ee854792b0f"]]},{"id":"a3ea742f50e691ad","type":"api-call-service","z":"afd5deb31ca9e1cd","name":"Ouvrir VR 2","server":"f1388c55.bbcd1","version":5,"debugenabled":false,"domain":"cover","service":"open_cover","areaId":[],"deviceId":[],"entityId":[],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1270,"y":180,"wires":[[]]},{"id":"dcfc8ee854792b0f","type":"api-call-service","z":"afd5deb31ca9e1cd","name":"Ouvrir VR 3","server":"f1388c55.bbcd1","version":5,"debugenabled":false,"domain":"cover","service":"open_cover","areaId":[],"deviceId":[],"entityId":[],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1270,"y":240,"wires":[[]]},{"id":"4088c166b58896cb","type":"api-call-service","z":"afd5deb31ca9e1cd","name":"Light 1 ON","server":"f1388c55.bbcd1","version":5,"debugenabled":false,"domain":"cover","service":"open_cover","areaId":[],"deviceId":[],"entityId":[],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1270,"y":80,"wires":[[]]},{"id":"f1388c55.bbcd1","type":"server","name":"Home Assistant RBT","addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"","connectionDelay":false,"cacheJson":false,"heartbeat":false,"heartbeatInterval":"","statusSeparator":"","enableGlobalContextStore":false}]
