Bonjour a tous,
J’essaie d’installer nodered sur mon HA et après l’installation je n’ai pas d’accès a la configuration de nodered afin de pouvoir renseigner le « credential_secret » ce qui fait que nodered ne démarre pas.
Dans l’onglet config j’ai :
Ce module complémentaire n’est pas configurable.
et voici le log :
s6-rc: info: service base-addon-banner: starting
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 14.2.1
You are running the latest version of this add-on.
System: Home Assistant OS 10.1 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2023.5.4
Home Assistant Supervisor: 2023.04.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-customizations: starting
s6-rc: info: service init-customizations successfully started
s6-rc: info: service init-nodered: starting
[08:47:32] FATAL:
[08:47:32] FATAL: Configuration of this add-on is incomplete.
[08:47:32] FATAL:
[08:47:32] FATAL: Please be sure to set the "credential_secret" option.
[08:47:32] FATAL:
[08:47:32] FATAL: The credential secret is an encryption token, much like
[08:47:33] FATAL: a password, that is used by Node-RED for encrypting
[08:47:33] FATAL: credentials you put into Node-RED.
[08:47:33] FATAL:
[08:47:33] FATAL: Just like a password, a credential secret can be
[08:47:33] FATAL: anything you like. Just be sure to store it somewhere
[08:47:33] FATAL: safe for later, e.g., in case of a recovery.
[08:47:33] FATAL:
s6-rc: warning: unable to start service init-nodered: command exited 1
s6-rc: info: service init-nginx successfully started
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service init-nginx: stopping
s6-rc: info: service init-customizations: stopping
s6-rc: info: service init-nginx successfully stopped
s6-rc: info: service init-customizations successfully stopped
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
Ou est mon erreur?
Merci a ceux qui me liront.
Bonne journée
HA est installer sur un PI4 avec 8Go de RAM.
Pour les log de HA si c’est bien dans parametres => Système=>Journaux il n’y a rien. J’ai aussi tenté de redémarrer le PI cela n’a rien changé.
