Problème d’accès extérieur avec un reverse proxy sur Synology.
Le plus étonnant : accès local possible ! Mais pas en externe.
Accès depuis https:\ha.truc.synology.me\ possible en local (et via http aussi).
Mais depuis l’extérieur, rien ne se passe… (voir ci-bas)
HA 2023.5.4
Synology 6.2
version | core-2023.5.4 |
dev | false |
hassio | true |
docker | true |
user | root |
virtualenv | false |
python_version | 3.10.11 |
os_name | Linux |
os_version | 6.1.21-v8 |
arch | aarch64 |
timezone | Europe/Paris |
config_dir | /config |
GitHub API | ok |
GitHub Content | ok |
GitHub Web | ok |
GitHub API Calls Remaining | 4995 |
Installed Version | 1.32.1 |
Stage | running |
Available Repositories | 1292 |
Downloaded Repositories | 4 |
logged_in | false |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | ok |
host_os | Home Assistant OS 10.1 |
update_channel | stable |
supervisor_version | supervisor-2023.04.1 |
agent_version | 1.5.1 |
docker_version | 23.0.3 |
disk_total | 28.6 GB |
disk_used | 5.7 GB |
healthy | true |
supported | true |
board | rpi3-64 |
supervisor_api | ok |
version_api | ok |
installed_addons | File editor (5.6.0), Terminal & SSH (9.7.0), Advanced SSH & Web Terminal (15.0.1), Z-Wave JS (0.1.82) |
dashboards | 2 |
resources | 2 |
views | 7 |
mode | storage |
oldest_recorder_run | 15 mai 2023 à 07:35 |
current_recorder_run | 25 mai 2023 à 03:35 |
estimated_db_size | 133.90 MiB |
database_engine | sqlite |
database_version | 3.40.1 |
Détails du problème
192.168.1.76 : IP de HA
192.168.1.20 : IP du NAS
192.168.1.1 : IP de la box
Mon fichier config :
default_config:
python_script:
browser_mod:
homeassistant:
external_url: https://ha.truc.synology.me
internal_url: http://192.168.1.76:8123
script: !include scripts.yaml
scene: !include scenes.yaml
http:
use_x_forwarded_for: true
trusted_proxies:
- 192.168.1.20
Routage en place
port externe 443 → 443 de NAS
port externe 80 → 80 de NAS
port externe 5001 → 5001 de NAS
Config du reverse proxy
Message si accès extérieur
[u]Logs/u]
Si qqun sait comment les trouver sur un synology … j’ai rien trouvé dans le centre des journaux
Et sur HA, rien dans les logs (Home Assistant Core, Supervisor, Host, DNS).
Please, help, des idées, des pistes, je suis prenneur …
