Bonjour à tous
Voila j’ai un souci depuis 2-3 jours, j’ai perdu le controle de mes equipements zigbee.
POur la config:
Rapsberry 4
debian 10
HASSIO en docker supervise
PiZigate 1
ZHA.
Voila presque de 2 ans que tout fonctionne à merveille mais plus rien, enfin presque, j’ai aussi un Zlinky et de temps à autre dans la carte ENERGIE j’ai des data , ce qui tente a prouver que ma PiZigate fonctionne encore.
j’ai aussi ca dans les logs si ca peux aider:
0x0E74: Device seen - marking the device available and resetting counter
0x0E74: Update device availability - device available: True - new availability: True - changed: False
0x4E24: last_seen is 11416993.775825739 seconds ago and ping attempts have been exhausted, marking the device unavailable
0x4E24: Update device availability - device available: False - new availability: False - changed: False
0x1341: Device seen - marking the device available and resetting counter
0x1341: Update device availability - device available: True - new availability: True - changed: False
0x3897: Device seen - marking the device available and resetting counter
0x3897: Update device availability - device available: True - new availability: True - changed: False
0x5390: Device seen - marking the device available and resetting counter
0x5390: Update device availability - device available: True - new availability: True - changed: False
[0x53CD:1:0x0b04]: async_update
[0x53CD:1:0x0b04]: Reading attributes in chunks: [‹ active_power ›, ‹ rms_current ›, ‹ rms_voltage ›]
[0x53CD:1:0x0b04] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=24, command_id=<GeneralCommand.Read_Attributes: 0>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
[0x53CD:1:0x0b04] Sending request: Read_Attributes(attribute_ids=[1291, 1288, 1285])
[0x7825:1:0x0b04]: async_update
[0x7825:1:0x0b04]: Reading attributes in chunks: [‹ active_power ›, ‹ active_power_max ›, ‹ apparent_power ›, ‹ rms_current ›, ‹ rms_current_max ›]
[0x7825:1:0x0b04] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=25, command_id=<GeneralCommand.Read_Attributes: 0>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
[0x7825:1:0x0b04] Sending request: Read_Attributes(attribute_ids=[1291, 1293, 1295, 1288, 1290])
[0x53CD:1:0x0b04]: failed to get attributes ‹ [‹ active_power ›, ‹ rms_current ›, ‹ rms_voltage ›] › on ‹ electrical_measurement › cluster:
[0x7825:1:0x0b04]: failed to get attributes ‹ [‹ active_power ›, ‹ active_power_max ›, ‹ apparent_power ›, ‹ rms_current ›, ‹ rms_current_max ›] › on ‹ electrical_measurement › cluster:
[0x7825:1:0x0b04]: Reading attributes in chunks: [‹ rms_voltage ›]
[0x7825:1:0x0b04] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=26, command_id=<GeneralCommand.Read_Attributes: 0>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
[0x7825:1:0x0b04] Sending request: Read_Attributes(attribute_ids=[1285])
0x59B2: Device seen - marking the device available and resetting counter
0x59B2: Update device availability - device available: True - new availability: True - changed: False
[0x7825:1:0x0b04]: failed to get attributes ‹ [‹ rms_voltage ›] › on ‹ electrical_measurement › cluster:
0x7713: Device seen - marking the device available and resetting counter
0x7713: Update device availability - device available: True - new availability: True - changed: False
0xF36F: Device seen - marking the device available and resetting counter
0xF36F: Update device availability - device available: True - new availability: True - changed: False
0xE5EF: last_seen is 6833987.291651249 seconds ago and ping attempts have been exhausted, marking the device unavailable
0xE5EF: Update device availability - device available: False - new availability: False - changed: False
0x353E: last_seen is 263090.58408141136 seconds ago and ping attempts have been exhausted, marking the device unavailable
0x353E: Update device availability - device available: False - new availability: False - changed: False
[0x53CD:1:0x0b04] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=27, command_id=<GeneralCommand.Read_Attributes: 0>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
[0x7825:1:0x0b04] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=28, command_id=<GeneralCommand.Read_Attributes: 0>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
0x44C4: Device seen - marking the device available and resetting counter
0x44C4: Update device availability - device available: True - new availability: True - changed: False
[0x7825:1:0x0b04] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=29, command_id=<GeneralCommand.Read_Attributes: 0>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
[0xAD6A](TRADFRI control outlet): Device seen - marking the device available and resetting counter
[0xAD6A](TRADFRI control outlet): Update device availability - device available: True - new availability: True - changed: False
0x53CD: Device seen - marking the device available and resetting counter
0x53CD: Update device availability - device available: True - new availability: True - changed: False
0xF10F: Device seen - marking the device available and resetting counter
0xF10F: Update device availability - device available: True - new availability: True - changed: False
0x7825: Device seen - marking the device available and resetting counter
0x7825: Update device availability - device available: True - new availability: True - changed: False
[0x7825:1:0x0702] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=30, command_id=<GeneralCommand.Read_Attributes: 0>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
[0x7825:1:0x0702] Sending request: Read_Attributes(attribute_ids=[256])
0xB193: Device seen - marking the device available and resetting counter
0xB193: Update device availability - device available: True - new availability: True - changed: False
[0x6819](TRADFRI control outlet): Device seen - marking the device available and resetting counter
[0x6819](TRADFRI control outlet): Update device availability - device available: True - new availability: True - changed: False
0x4E24: last_seen is 11417062.777961016 seconds ago and ping attempts have been exhausted, marking the device unavailable
[0x53CD:1:0x0b04] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=31, command_id=<GeneralCommand.Read_Attributes: 0>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
[0x7825:1:0x0b04] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=32, command_id=<GeneralCommand.Read_Attributes: 0>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
0x8DDC: Device seen - marking the device available and resetting counter
0x8DDC: Update device availability - device available: True - new availability: True - changed: False
[0x7825:1:0x0b04] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=33, command_id=<GeneralCommand.Read_Attributes: 0>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
[0x53CD:1:0x0b04] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=34, command_id=<GeneralCommand.Read_Attributes: 0>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
[0x7825:1:0x0b04] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=35, command_id=<GeneralCommand.Read_Attributes: 0>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
0x353E: last_seen is 263154.5845749378 seconds ago and ping attempts have been exhausted, marking the device unavailable
[0x7825:1:0x0b04] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=36, command_id=<GeneralCommand.Read_Attributes: 0>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
[0x7825:1:0x0702] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=37, command_id=<GeneralCommand.Read_Attributes: 0>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
Qui aurait une idée sur l’origine du problème ?? merci
