Voici les messages que je trouve dans l’onglet ‹ core › de system
[services.d] starting services
[services.d] done.
2020-12-29 19:11:02 WARNING (MainThread) [homeassistant.config_entries] Config entry for upnp not ready yet. Retrying in 10 seconds
2020-12-29 19:11:05 ERROR (MainThread) [custom_components.hacs] Cannot connect to host api.github.com:443 ssl:default [Try again]
2020-12-29 19:11:05 CRITICAL (MainThread) [custom_components.hacs] Your GitHub token is not valid
2020-12-29 19:11:05 WARNING (MainThread) [homeassistant.config_entries] Config entry for hacs not ready yet. Retrying in 5 seconds
2020-12-29 19:11:08 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-12-29 19:11:08 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for scheduler which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-12-29 19:11:10 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=55 from 2020-12-29 18:10:34.574455)
2020-12-29 19:11:10 ERROR (MainThread) [metno] https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned Cannot connect to host aa015h6buqvih86i1.api.met.no:443 ssl:default [Try again]
2020-12-29 19:11:15 ERROR (MainThread) [metno] https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned Cannot connect to host aa015h6buqvih86i1.api.met.no:443 ssl:default [Try again]
2020-12-29 19:11:22 WARNING (MainThread) [homeassistant.config_entries] Config entry for upnp not ready yet. Retrying in 20 seconds
2020-12-29 19:12:38 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching Orange Livebox data
2020-12-30 04:12:00 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed
[SQL: DELETE FROM events WHERE events.time_fired < ?]
[parameters: ('2020-12-12 14:04:39.170151',)]
(Background on this error at: http://sqlalche.me/e/13/4xp6)
2020-12-30 04:12:00 WARNING (Recorder) [homeassistant.components.recorder.purge] Error purging history: (sqlite3.DatabaseError) database disk image is malformed
2020-12-30 08:39:36 ERROR (MainThread) [custom_components.hacs] custom-components/sensor.rpi_power - Repository is archived.
2020-12-30 10:45:08 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching Orange Livebox data
2020-12-30 10:49:29 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.8/site-packages/aiohttp/connector.py", line 1005, in _create_direct_connection
hosts = await asyncio.shield(host_resolved)
File "/usr/local/lib/python3.8/site-packages/aiohttp/connector.py", line 858, in _resolve_host
await event.wait()
File "/usr/local/lib/python3.8/site-packages/aiohttp/locks.py", line 38, in wait
raise self._exc
File "/usr/local/lib/python3.8/site-packages/aiohttp/connector.py", line 871, in _resolve_host
addrs = await self._resolver.resolve(host, port, family=self._family)
File "/usr/local/lib/python3.8/site-packages/aiohttp/resolver.py", line 31, in resolve
infos = await self._loop.getaddrinfo(
File "/usr/local/lib/python3.8/asyncio/base_events.py", line 825, in getaddrinfo
return await self.run_in_executor(
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
result = self.fn(*self.args, **self.kwargs)
File "/usr/local/lib/python3.8/socket.py", line 918, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
The above exception was the direct cause of the following exception:
File "/config/custom_components/hacs/hacsbase/hacs.py", line 283, in recurring_tasks_installed
await self.handle_critical_repositories()
File "/config/custom_components/hacs/hacsbase/hacs.py", line 195, in handle_critical_repositories
critical = await self.data_repo.get_contents("critical")
File "/usr/local/lib/python3.8/site-packages/aiogithubapi/objects/repository/__init__.py", line 113, in get_contents
response = await self.client.get(endpoint=_endpoint, params=_params)
File "/usr/local/lib/python3.8/site-packages/aiogithubapi/client.py", line 36, in get
response = await async_call_api(
File "/usr/local/lib/python3.8/site-packages/backoff/_async.py", line 133, in retry
ret = await target(*args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/aiogithubapi/helpers.py", line 59, in async_call_api
result = await session.get(url, params=params or {}, headers=_headers)
File "/usr/local/lib/python3.8/site-packages/aiohttp/client.py", line 527, in _request
conn = await self._connector.connect(
File "/usr/local/lib/python3.8/site-packages/aiohttp/connector.py", line 541, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.8/site-packages/aiohttp/connector.py", line 898, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File "/usr/local/lib/python3.8/site-packages/aiohttp/connector.py", line 1017, in _create_direct_connection
raise ClientConnectorError(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host api.github.com:443 ssl:default [Try again]
2020-12-30 10:49:29 ERROR (MainThread) [custom_components.hacs] Cannot connect to host api.github.com:443 ssl:default [Try again]
2020-12-30 10:49:59 ERROR (MainThread) [custom_components.hacs] <Plugin nielsfaber/scheduler-card> Cannot connect to host api.github.com:443 ssl:default [Try again]
2020-12-30 10:49:59 ERROR (MainThread) [custom_components.hacs] nielsfaber/scheduler-card - Cannot connect to host api.github.com:443 ssl:default [Try again]
2020-12-30 10:49:59 ERROR (MainThread) [custom_components.hacs] <Integration nielsfaber/scheduler-component> Cannot connect to host api.github.com:443 ssl:default [Try again]
2020-12-30 10:49:59 ERROR (MainThread) [custom_components.hacs] nielsfaber/scheduler-component - Cannot connect to host api.github.com:443 ssl:default [Try again]
2020-12-30 10:49:59 ERROR (MainThread) [custom_components.hacs] <Plugin ciotlosm/lovelace-thermostat-dark-card> Cannot connect to host api.github.com:443 ssl:default [Try again]
2020-12-30 10:49:59 ERROR (MainThread) [custom_components.hacs] ciotlosm/lovelace-thermostat-dark-card - Cannot connect to host api.github.com:443 ssl:default [Try again]
2020-12-30 10:49:59 ERROR (MainThread) [custom_components.hacs] <Integration hacs/integration> Cannot connect to host api.github.com:443 ssl:default [Try again]
2020-12-30 10:49:59 ERROR (MainThread) [custom_components.hacs] hacs/integration - Cannot connect to host api.github.com:443 ssl:default [Try again]
2020-12-30 10:49:59 ERROR (MainThread) [custom_components.hacs] <Theme aFFekopp/noctis> Cannot connect to host api.github.com:443 ssl:default [Try again]
2020-12-30 10:49:59 ERROR (MainThread) [custom_components.hacs] aFFekopp/noctis - Cannot connect to host api.github.com:443 ssl:default [Try again]
2020-12-30 10:49:59 ERROR (MainThread) [custom_components.hacs] <Theme myleskeeffe/clear-theme-dark-vibrant> Cannot connect to host api.github.com:443 ssl:default [Try again]
2020-12-30 10:49:59 ERROR (MainThread) [custom_components.hacs] myleskeeffe/clear-theme-dark-vibrant - Cannot connect to host api.github.com:443 ssl:default [Try again]
2020-12-30 10:58:51 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching Orange Livebox data
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
Client error on /homeassistant/restart request Server disconnected
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[11:55:35] INFO: Update udev information
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] done.
2020-12-30 11:55:42 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for scheduler which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-12-30 11:55:42 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
En image
