L’action physique sur l’interrupteur ne remonte pas correctement, cela fonctionnais avant le dernière mise à jour il y a deux semaines. Les automatismes les concernant ne fonctionnent donc plus.
Dans HA cela fonctionne parfaitement
Un autre matériel lui fonctionne parfaitement.
J’ai déappairé et réappairé le matériel, pas de changement
Redémarrage ha
Des idées ou chercher?
Log Zigbeee2Mqtt si j’action l1 physiquement (l1 et l2 à off au départ)
Passage à ON
debug 2023-05-09 09:54:35Received Zigbee message from 'EclairageSalon02', type 'attributeReport', cluster 'genOnOff', data '{"onOff":1}' from endpoint 1 with groupID 0
info 2023-05-09 09:54:35MQTT publish: topic 'zigbee2mqtt/EclairageSalon02', payload '{"action":null,"led_enable":true,"led_enable_l1":null,"led_enable_l2":null,"led_state":"ON","led_state_l1":null,"led_state_l2":null,"linkquality":80,"operation_mode":"control_relay","state":"ON","state_l1":"ON","state_l2":"OFF"}'
Passage à OFF
debug 2023-05-09 09:55:55Received Zigbee message from 'EclairageSalon02', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
info 2023-05-09 09:55:55MQTT publish: topic 'zigbee2mqtt/EclairageSalon02', payload '{"action":null,"led_enable":true,"led_enable_l1":null,"led_enable_l2":null,"led_state":"ON","led_state_l1":null,"led_state_l2":null,"linkquality":80,"operation_mode":"control_relay","state":"OFF","state_l1":"ON","state_l2":"OFF"}'
Log Zigbeee2Mqtt si j’action l1 via HA (l1 et l2 à off au départ)
Passage à ON
debug 2023-05-09 10:00:31Received MQTT message on 'zigbee2mqtt/EclairageSalon02/l1/set' with data 'ON'
debug 2023-05-09 10:00:31Publishing 'set' 'state' to 'EclairageSalon02'
debug 2023-05-09 10:00:32Received Zigbee message from 'EclairageSalon02', type 'attributeReport', cluster 'genOnOff', data '{"onOff":1}' from endpoint 1 with groupID 0
info 2023-05-09 10:00:32MQTT publish: topic 'zigbee2mqtt/EclairageSalon02', payload '{"action":null,"led_enable":true,"led_enable_l1":null,"led_enable_l2":null,"led_state":"ON","led_state_l1":null,"led_state_l2":null,"linkquality":87,"operation_mode":"control_relay","state":"ON","state_l1":"OFF","state_l2":"OFF"}'
info 2023-05-09 10:00:32MQTT publish: topic 'zigbee2mqtt/EclairageSalon02', payload '{"action":null,"led_enable":true,"led_enable_l1":null,"led_enable_l2":null,"led_state":"ON","led_state_l1":null,"led_state_l2":null,"linkquality":87,"operation_mode":"control_relay","state":"ON","state_l1":"ON","state_l2":"OFF"}'
debug 2023-05-09 10:00:44Saving state to file /config/zigbee2mqtt/state.json
Passage à OFF
debug 2023-05-09 10:01:41Received MQTT message on 'zigbee2mqtt/EclairageSalon02/l1/set' with data 'OFF'
debug 2023-05-09 10:01:41Publishing 'set' 'state' to 'EclairageSalon02'
debug 2023-05-09 10:01:41Received Zigbee message from 'EclairageSalon02', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
info 2023-05-09 10:01:41MQTT publish: topic 'zigbee2mqtt/EclairageSalon02', payload '{"action":null,"led_enable":true,"led_enable_l1":null,"led_enable_l2":null,"led_state":"ON","led_state_l1":null,"led_state_l2":null,"linkquality":91,"operation_mode":"control_relay","state":"OFF","state_l1":"ON","state_l2":"OFF"}'
info 2023-05-09 10:01:41MQTT publish: topic 'zigbee2mqtt/EclairageSalon02', payload '{"action":null,"led_enable":true,"led_enable_l1":null,"led_enable_l2":null,"led_state":"ON","led_state_l1":null,"led_state_l2":null,"linkquality":87,"operation_mode":"control_relay","state":"OFF","state_l1":"OFF","state_l2":"OFF"}'
## System Information
version | core-2023.5.2
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.10.11
os_name | Linux
os_version | 6.1.25
arch | x86_64
timezone | Europe/Brussels
config_dir | /config
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
Installed Version | 1.32.1
Stage | running
Available Repositories | 1285
Downloaded Repositories | 2
</details>
logged_in | false
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
host_os | Home Assistant OS 10.1
update_channel | stable
supervisor_version | supervisor-2023.04.1
agent_version | 1.5.1
docker_version | 23.0.3
disk_total | 30.8 GB
disk_used | 11.1 GB
healthy | true
supported | true
board | ova
supervisor_api | ok
version_api | ok
installed_addons | Mosquitto broker (6.2.1), Node-RED (14.1.5), File editor (5.6.0), ESPHome (2023.4.4), Zigbee2MQTT (1.30.4-1), Terminal & SSH (9.7.0), Studio Code Server (5.5.7)
</details>
dashboards | 2
resources | 1
views | 13
mode | storage
</details>
oldest_recorder_run | 5 mai 2023 à 16:12
current_recorder_run | 6 mai 2023 à 12:10
estimated_db_size | 153.42 MiB
database_engine | sqlite
database_version | 3.40.1
</details>
