J’ai plusieurs erreur dans les journaux et je ne trouve pas d’où cela provient !!
Quelqu’un a-t-il déjà ce message d’erreur ?
Merci d’avance
saisissez ou collez du code ici
Source: helpers/entity.py:695
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 15 avril 2022, 21:08:14 (206 occurrences)
Last logged: 10:29:54
[548229116784] Error handling message: Unknown error
[547769610496] Error handling message: Unknown error
[548091020096] Error handling message: Unknown error
[547364845216] Error handling message: Unknown error
[548049839920] Error handling message: Unknown error
File "/usr/src/homeassistant/homeassistant/components/websocket_api/connection.py", line 107, in async_handle
handler(self.hass, self, schema(msg))
File "/config/custom_components/browser_mod/connection.py", line 44, in handle_update
devices[deviceID].update(msg.get("data", None))
File "/config/custom_components/browser_mod/connection.py", line 94, in update
self.sensor.data = data.get("browser")
File "/config/custom_components/browser_mod/helpers.py", line 106, in data
self.updated()
File "/config/custom_components/browser_mod/sensor.py", line 27, in updated
self.schedule_update_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 695, in schedule_update_ha_state
self.hass.add_job(self.async_update_ha_state(force_refresh))
AttributeError: 'NoneType' object has no attribute 'add_job'
## Ma configuration
System Health
version |
core-2022.3.8 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.9.9 |
os_name |
Linux |
os_version |
5.10.103-v8 |
arch |
aarch64 |
timezone |
Europe/Brussels |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
GitHub API Calls Remaining |
5000 |
Installed Version |
1.24.5 |
Stage |
running |
Available Repositories |
1038 |
Downloaded Repositories |
94 |
logged_in |
true |
subscription_expiration |
28 avril 2022, 02:00 |
relayer_connected |
true |
remote_enabled |
true |
remote_connected |
true |
alexa_enabled |
false |
google_enabled |
true |
remote_server |
eu-central-1-2.ui.nabu.casa |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 7.6 |
update_channel |
stable |
supervisor_version |
supervisor-2022.04.0 |
docker_version |
20.10.9 |
disk_total |
219.4 GB |
disk_used |
44.7 GB |
healthy |
true |
supported |
true |
board |
rpi4-64 |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
Samba share (9.5.1), File editor (5.3.3), AirSonos (3.3.0), Home Assistant Google Drive Backup (0.102.0), MariaDB (2.4.0), Node-RED (11.1.1), Studio Code Server (4.2.0), VLC (0.1.3), AirCast (3.3.0), SSH & Web Terminal (10.1.1), Mosquitto broker (6.0.1), motionEye (0.18.0), phpMyAdmin (0.7.1), Spotify Connect (0.11.0), DahuaVTO2MQTT (1.0.14) |
Lovelace
dashboards |
3 |
resources |
71 |
views |
45 |
mode |
storage |
Spotify
api_endpoint_reachable |
ok |
