J’ai déjà les caméras…
J’ai essayé sans succès.
Faut-il avoir un abonnement au cloud pour pouvoir faire cette intégration ?
Je n’ai pas de caméra Eufy, donc je ne sais pas. Regarde si tu as plus d’infos dans les logs.
Merci pour la réponse.
Un nouveau test d’automatisme :
description: ""
- type: motion
platform: device
device_id: a22db97d7df9f2d84e0c1a7fd316badf
entity_id: binary_sensor.detecteur_aqara1_occupancy
domain: binary_sensor
condition: []
- type: turn_on
device_id: aa6c444501a04e81c98f761cc691b108
entity_id: light.cuisine_3
domain: light
flash: long
alias: test cuisine2
Logger: aiohttp.server
Source: components/config/automation.py:70
First occurred: 10:18:50 (1 occurrences)
Last logged: 10:18:50
Error handling request
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 94, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 80, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 145, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/__init__.py", line 145, in post
self._write_value(hass, current, config_key, data)
File "/usr/src/homeassistant/homeassistant/components/config/automation.py", line 70, in _write_value
cur_value[CONF_ID] = uuid.uuid4().hex
TypeError: 'str' object does not support item assignment
Ceci génère une erreur 500.
Une idée ?
Merci pour les réponses éventuelles …
Je joins les informations Système :
## System Information
version | core-2023.2.1
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.10.7
os_name | Linux
os_version | 5.15.80
arch | x86_64
timezone | Europe/Paris
config_dir | /config
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
Installed Version | 1.30.1
Stage | running
Available Repositories | 1193
Downloaded Repositories | 6
</details>
logged_in | true
subscription_expiration | 13 février 2023 à 01:00
relayer_connected | true
remote_enabled | true
remote_connected | true
alexa_enabled | true
google_enabled | false
remote_server | eu-central-1-1.ui.nabu.casa
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
host_os | Home Assistant OS 9.4
update_channel | stable
supervisor_version | supervisor-2023.01.1
agent_version | 1.4.1
docker_version | 20.10.19
disk_total | 30.8 GB
disk_used | 7.3 GB
healthy | true
supported | true
board | ova
supervisor_api | ok
version_api | ok
installed_addons | File editor (5.5.0), Terminal & SSH (9.6.1), Mosquitto broker (6.1.3), Studio Code Server (5.5.2), Zigbee2MQTT (1.29.2-1), ESPHome (2022.12.8)
</details>
dashboards | 3
resources | 3
views | 3
mode | storage
</details>
oldest_recorder_run | 25 janvier 2023 à 15:37
current_recorder_run | 4 février 2023 à 10:44
estimated_db_size | 145.36 MiB
database_engine | sqlite
database_version | 3.38.5
</details>
Commence par faire une automatisation via l’interface.
Pour le moment, évite le yaml.
Ca y est !!!
Les premiers automatismes fonctionnent enfin …
L’erreur provenait d’une mauvaise automatisation enregistrée dans le fichier automations.yaml
Ceci provoquait une erreur 500 et empêchait les autres automatismes…
Un grand merci pour laide apportée.
@lucgiraud et @Giga77, j’ai édité les mails perso des extraits de config
J’ai aussi un problème de création d’automatisation. Je souhaite tout simplement réaliser l’extinction d’une prise à une certaine heure. Lorsque je créer l’automatisation, une fois que j’ai renseigné son nom, j’ai le bouton « enregistré » qui disparait.
En lisant ce sujet, j’ai pu constater que cette automatisation était bien enregistrée dans YAML mais n’apparait pas dans « Automatisation » et ne s’exécute pas.
Merci bien aux personnes qui m’aiderons.
Salut @laurentg18
Crée un nouveau sujet. Ta configuration est différente. Ton soucis est différent.
Evite les screenshots (ç’est illisible), essaie de copier ta config en texte, et le log aussi avec du texte préformaté.
Et j’ai quelques questions. On va éviter de polluer ce sujet.
