J’utilises des rapsberry pi3 avec un hat hifiberry Amp+
[center]## System Information
version | core-2023.4.6 |
dev | false |
hassio | true |
docker | true |
user | root |
virtualenv | false |
python_version | 3.10.10 |
os_name | Linux |
os_version | 6.1.25 |
arch | x86_64 |
timezone | Europe/Paris |
config_dir | /config |
GitHub API | ok |
GitHub Content | ok |
GitHub Web | ok |
GitHub API Calls Remaining | 4991 |
Installed Version | 1.32.1 |
Stage | running |
Available Repositories | 1344 |
Downloaded Repositories | 40 |
HACS Data | ok |
logged_in | true |
subscription_expiration | 16 février 2024 à 01:00 |
relayer_connected | true |
relayer_region | eu-central-1 |
remote_enabled | true |
remote_connected | true |
alexa_enabled | true |
google_enabled | true |
remote_server | eu-central-1-5.ui.nabu.casa |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | ok |
host_os | Home Assistant OS 10.1 |
update_channel | stable |
supervisor_version | supervisor-2023.04.1 |
agent_version | 1.5.1 |
docker_version | 23.0.3 |
disk_total | 30.8 GB |
disk_used | 13.1 GB |
healthy | true |
supported | true |
board | ova |
supervisor_api | ok |
version_api | ok |
installed_addons | Studio Code Server (5.5.7), Samba share (10.0.1), Terminal & SSH (9.7.0), File editor (5.6.0), Grafana (8.2.2), InfluxDB (4.6.0), motionEye (0.19.1), Spotify Connect (0.12.3) |
dashboards | 18 |
resources | 32 |
views | 78 |
mode | storage |
oldest_recorder_run | 29 avril 2023 à 15:03 |
current_recorder_run | 1 mai 2023 à 11:43 |
estimated_db_size | 20.57 MiB |
database_engine | sqlite |
database_version | 3.38.5 |
Cependant je n’arrive pas à installer un deuxième Hifiberry et quand je fais la modification prévue:
Be aware it has to be enabled in the /etc/audiocontrol2.conf on the device:
[webserver] enable=yes port=81 socketio_enabled=True
lorsque je reboot, je perds la modification.
je pense que c’est la raison pour laquelle je ne peux pas intégrer ce nouvel appareil.
Merci pour vos aides…
