Bonjour, depuis quelque jour je n’arrive plus à effectuer les mise à jour des applications.
Par exemple pour file editor, voici le message d’erreur:
Error updating File editor: ‹ AddonManager.update › blocked from execution, was unable to update plugin(s) audio and all plugins must be up to date first
Le plus sûr c’est de commencer par mettre à jour le core. Possible que ce soit un prérequis pour fileditor.
Et ne pas hésiter à redéamarrer HA si ça coince toujours
La mise à jour du Core m’indique le même message. Même après plusieurs redémarrage.
Logger: homeassistant.components.websocket_api.http.connection
Source: components/hassio/update.py:301
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 17:04:49 (2 occurrences)
Last logged: 17:13:25
[547403686928] Error updating Home Assistant Core 'HomeAssistantCore.update' blocked from execution, was unable to update plugin(s) audio and all plugins must be up to date first
[546913223872] Error updating Home Assistant Core 'HomeAssistantCore.update' blocked from execution, was unable to update plugin(s) audio and all plugins must be up to date first
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 299, in async_install
await async_update_core(self.hass, version=version, backup=backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 45, in _wrapper
raise HassioAPIError(data["message"])
homeassistant.components.hassio.handler.HassioAPIError: 'HomeAssistantCore.update' blocked from execution, was unable to update plugin(s) audio and all plugins must be up to date first
The above exception was the direct cause of the following exception:
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 199, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1713, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1750, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 676, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 930, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 713, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 152, in async_install
await entity.async_install_with_progress(version, backup)
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 411, in async_install_with_progress
await self.async_install(version, backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 301, in async_install
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Core 'HomeAssistantCore.update' blocked from execution, was unable to update plugin(s) audio and all plugins must be up to date first
Effectivement j’en ai désinstallé un.
Je viens d’executer la commande mais toujours le même message.
Je ne comprend vraiment pas ce qui a pu se passer.
Merci encore pour l’aide
