https://github.com/KoljaWindeler/ytube_music_player
Bonjours, à tous, je rencontre un problème pour installer cette addon, le cookie est refusé par l’addon. J’ai essayer avec plusieurs navigateurs différent, de modifié le cookie, mais à chaque fois j’ai l’erreur suivante
Something with your cookie wasn't right. Format and fields are ok but the login failed
Logger: custom_components.ytube_music_player.config_flow
Source: custom_components/ytube_music_player/config_flow.py:201
Integration: YouTube Music Player (documentation, issues)
First occurred: 00:09:39 (33 occurrences)
Last logged: 01:11:02
Traceback (most recent call last): File "/config/custom_components/ytube_music_player/config_flow.py", line 191, in async_check_data YTMusic.setup(filepath = user_input[CONF_HEADER_PATH], headers_raw = c) File "/usr/local/lib/python3.9/site-packages/ytmusicapi/ytmusic.py", line 164, in setup return setup(filepath, headers_raw) File "/usr/local/lib/python3.9/site-packages/ytmusicapi/setup.py", line 36, in setup raise Exception( Exception: The following entries are missing in your headers: x-goog-authuser, cookie. Please try a different request (such as /browse) and make sure you are logged in.
Traceback (most recent call last): File "/config/custom_components/ytube_music_player/config_flow.py", line 191, in async_check_data YTMusic.setup(filepath = user_input[CONF_HEADER_PATH], headers_raw = c) File "/usr/local/lib/python3.9/site-packages/ytmusicapi/ytmusic.py", line 164, in setup return setup(filepath, headers_raw) File "/usr/local/lib/python3.9/site-packages/ytmusicapi/setup.py", line 36, in setup raise Exception( Exception: The following entries are missing in your headers: x-goog-authuser. Please try a different request (such as /browse) and make sure you are logged in.
System Health
version
core-2021.12.8
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
user
root
virtualenv
false
python_version
3.9.7
os_name
Linux
os_version
5.10.63-v8
arch
aarch64
timezone
Europe/Paris
GitHub API
ok
Github API Calls Remaining
4631
Installed Version
1.19.0
Stage
running
Available Repositories
933
Downloaded Repositories
25
logged_in
false
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
pending
host_os
Home Assistant OS 7.1
update_channel
stable
supervisor_version
supervisor-2021.12.2
docker_version
20.10.9
disk_total
111.1 GB
disk_used
8.6 GB
healthy
true
supported
true
board
rpi4-64
supervisor_api
ok
version_api
ok
installed_addons
Duck DNS (1.14.0), File editor (5.3.3), RPC Shutdown (2.2), Samba share (9.5.1), ESPHome (2021.12.3), Home Assistant Google Drive Backup (0.105.2), Terminal & SSH (9.3.0), Glances (0.14.1)
Bonjour, oui je suis sur, j’ai même agrandi les screens pour bien voir, j’ai même essayé sur plusieurs navigateurs différents et prendre le cookie de manière différente… Je sèche.
Ton HA est à jour sur la dernière version aussi ? Car j’ai remarqué que depuis les dernières mise à jour de HA que beaucoup d’addon nécessité des mises à jour…
J’ai plusieurs ligne cookie, comme set_cookie, mais je prend bien le cookie, et quand tu veux le copié le code ce mais bien intégralement… Je comprend pas, il me dit que le cookie est bon, mais qu’il n’arrive pas à ce connecter.
J’utilise l’authentification à 2 facteurs sur Google cela joue t’il sur l’addon ?
Salut ! Je viens d’intégrer youtube music et j’avais fait l’erreur malgré l’explication claire de ne copier que la partie « cookie » et j’ai obtenue le même message d’erreur que toi une fois la totalité copier ( de « accept : / » à « x-goog-visitor-id : XXXX) » c’est passé !
Problème réglé effectivement c’était suite à une mauvaise intégration du cookie, merci beaucoup…
Par contre vous savez comment sélectionner la source externe de diffusion ? J’ai plusieurs Google home, et j’aimerais pouvoir sélectionner le lieux où je diffuse, car la j’ai du faire une card par pièce, pas cool…
De rien, ça fait plaisir de pouvoir aider, avec mon faible niveau, je suis spécialisé dans les tuto qui fonctionne pas, je cumule la malchance c dingue !!
Pour les multiples sources je crois qu’il ya dans le read me des explications pour le faire. Va jeter un œil.
J’espère que ça marche pour vous, pq comme je le disais j’ai toujours des merde et la pour le coup, ça marche, g accès à mes playlist etc mais j’ai une erreur lorsque je lance la lecture !
moi j’arrive plus a accéder a mets playlists du navigateur, je peu juste les lancer directe. Ca me fait ca depus 1 semaine.
Edit:
j’ai trouvé le problème, j’ai refait les cookies. Par contre j’ai ouvert une fenêtre de navigation privé dans chrome pour que les cookies soit correcte autrement ca fonctionnait pas.
Merci beaucoup cela à fonctionner, mais j’ai encore une erreur qui me créer une notification quand je clique sur le bouton power en haut à droite.
Cela serais du à quoi ?
Il te faut configurer un lecteur par default, dans les configurations ou sinon faut selectionner un lecteur en premier et selectionner une playlist et ca devait démarrer.
perso je préfère cette carte qui m’apporte d’avantages de possibilités et correspond plus à mon besoin.
grace au input select je peux choisir ma sortie (salon, salle de bain ect… mais aussi meme sur un groupe de google home pour diffuser dans le salon ET dans la salle de bain par exemple)
un deuxieme input select permet de choisir entre Playlist, les morceaux likés, les playlist de radio ect…
un input booleen alimentera automatiquement ma liste de playlist, pas besoin de créer un bouton avec l’id de la playlist a chaque nouvelle playlist ou album
un input boolean pour choisir la lecture continue ou aléatoire, cette fonction n’est pas présente dans le navigateur multimedia d’HA et dans d’autre carte.
J’ai essayé cette solution pour avoir la radio, j’ai jamais réussi à la mettre en place, pourtant j’ai fait les input sélect, et les scripts, mais ça n’a jamais fonctionné…
En plus la il y a que le code de la carte, sans les scripts, et le code des input cela ne fonctionnera pas.
@jybi89 c’est sympa avec les inputs , mais j’ai enlever car ca me prends trop de place.
Oui, il y a tout le code sur le github pour les inputs si besoin.
Alors j’ai une question tte bête mais comment je sais combien d’espace il faut ?? Il y a une norme ?? Dans ma logique je décale les information concernant le point précédent mais suivant les codes je vois plus ou moins d’espace g du mal à comprendre !
bonjour
il n’y a pas moyen d’avoir une liste déroulante des appareils dispo sur la carte afin de pouvoir sélectionner avant de lancer la playlist
merci
