Rhooo, c’est bôôô quand tu formates, @WarC0zes
Bonsoir
Avec l’addon SiliconLab ça flash la 7.3.1.0
J’ai mis adapter: « ember » au lieu de « ezsp » comme préconisé
J’ai supprimé sliconLab Multiprotocol
Mais j’ai toujours un problème avec Zigbee2mqtt
[19:01:46] INFO: Starting Zigbee2MQTT...
[2024-07-16 19:01:56] info: z2m: Logging to console, file (filename: log.log)
[2024-07-16 19:01:56] info: z2m: Starting Zigbee2MQTT version 1.39.0 (commit #unknown)
[2024-07-16 19:01:56] info: z2m: Starting zigbee-herdsman (0.50.1)
[2024-07-16 19:01:57] info: zh:ember: Using default stack config.
[2024-07-16 19:01:57] info: zh:ember: ======== Ember Adapter Starting ========
[2024-07-16 19:01:57] info: zh:ember:ezsp: ======== EZSP starting ========
[2024-07-16 19:01:57] info: zh:ember:uart:ash: ======== ASH NCP reset ========
[2024-07-16 19:01:57] info: zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2024-07-16 19:01:57] info: zh:ember:uart:ash: Serial port opened
[2024-07-16 19:01:57] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-07-16 19:01:58] info: zh:ember:uart:ash: ======== ASH connected ========
[2024-07-16 19:01:58] info: zh:ember:uart:ash: ======== ASH started ========
[2024-07-16 19:01:58] info: zh:ember:ezsp: ======== EZSP started ========
[2024-07-16 19:01:58] error: z2m: Error while starting zigbee-herdsman
[2024-07-16 19:01:58] error: z2m: Failed to start zigbee
[2024-07-16 19:01:58] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-07-16 19:01:58] error: z2m: Exiting...
[2024-07-16 19:01:58] error: z2m: Error: NCP EZSP protocol version of 12 does not match Host version 13
at EmberAdapter.emberVersion (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1714:19)
at EmberAdapter.initEzsp (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:893:9)
at EmberAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:2722:24)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:129:29)
at Zigbee.start (/app/lib/zigbee.ts:63:27)
at Controller.start (/app/lib/controller.ts:139:27)
at start (/app/index.js:154:5)
Tu as bien désinstallé et mis en ignoré Zigbee Home Automation ?
[19:01:46] INFO: Starting Zigbee2MQTT…
[2024-07-16 19:01:58] error: z2m: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
[2024-07-16 19:01:58] error: z2m: Exiting…
Si tu as bien désinstallé ZHA, il faudrait essayer de flasher ta clé SkyConnect manuellement (via le Terminal et SSH) avec le firmware 7.4.2 (tu trouveras les liens pour le faire sur le post que j’ai mis plus haut.
Pense à mettre tes logs en texte formaté (« </> »).
Ce truc bloque à priori : NCP EZSP protocol version of 12 does not match Host version 13
@jjhome , met ton code ou log avec la balise texte preformaté
Je ne vais pas modifier tout t’est message.
Pour ember il faut une version supérieure a 7.4
Au Maximum j’ai trouvé V7.4.0.0 en beta
Tu l’as ici en version 7.4.2
Tu n’as pas beaucoup cherché pour trouver une version supérieure du firmware, je t’ai mis le lien direct dans le message 18 ainsi que les liens pour flasher ta clé. Je peux difficilement faire plus…
Après quelques vacances je me suis remis à cette galère:
Finalement ça marche.
Pour résumer, si ça peut aider quelqu’un:
- Pas de ZHA
- Pas de Silabs Multiprotocols
- Suppression de configuration.yaml dans zigbee2mqtt avant redémarrage
- Type ember au lieu de ezsp
- obéissance à MQTT qui m’impose un utilisateur nommé "homeassistant
- Flash de la clé Skyconnect en 7.4.3
Reste un warning qui n’a pas d’influence
Ouf et merci
Non, tu mets celui que tu veux dans la configuration ; là c’est celui par défaut.
J’ai bien essayé, j’enregistre mais quand je reviens, il n’a pas changé.
Mais j’arrête, Ca m’énerve.
