Cela fait longtemps que j’ai installé l’add-on PSA Car Controller, et je n’ai jamais réussi à le faire fonctionner, notamment parce que je ne reçois jamais le SMS.
J’ai beaucoup cherché, mais rien à faire, je dois louper un truc, c’est pourquoi je sollicite votre aide et vos idées.
Je suis en dernière version HA et PSA Car Controller et voilà ce que j’obtiens:
Les logs:
2023-01-11 11:48:22,848 :: ERROR :: No config file
2023-01-11 11:48:22,855 :: WARNING :: Can't get language
2023-01-11 11:48:24,692 :: INFO :: update_data
2023-01-11 11:48:24,768 :: INFO :: * Running on http://0.0.0.0:5000/ (Press CTRL+C to quit)
2023-01-11 11:51:15,131 :: INFO :: 172.30.32.1 - - [11/Jan/2023 11:51:15] "e[37mGET / HTTP/1.1e[0m" 200 -
2023-01-11 11:51:15,185 :: INFO :: 172.30.32.1 - - [11/Jan/2023 11:51:15] "e[37mGET /assets/clientside.js HTTP/1.1e[0m" 200 -
2023-01-11 11:51:15,398 :: INFO :: 172.30.32.1 - - [11/Jan/2023 11:51:15] "e[37mGET /_dash-layout HTTP/1.1e[0m" 200 -
2023-01-11 11:51:15,403 :: INFO :: 172.30.32.1 - - [11/Jan/2023 11:51:15] "e[37mGET /_dash-dependencies HTTP/1.1e[0m" 200 -
2023-01-11 11:51:15,631 :: INFO :: 172.30.32.1 - - [11/Jan/2023 11:51:15] "e[37mPOST /_dash-update-component HTTP/1.1e[0m" 200 -
2023-01-11 11:51:15,696 :: INFO :: 172.30.32.1 - - [11/Jan/2023 11:51:15] "e[37mGET /config_login HTTP/1.1e[0m" 200 -
2023-01-11 11:51:15,707 :: INFO :: 172.30.32.1 - - [11/Jan/2023 11:51:15] "e[37mGET /assets/images/settings.svg HTTP/1.1e[0m" 200 -
2023-01-11 11:51:15,859 :: INFO :: 172.30.32.1 - - [11/Jan/2023 11:51:15] "e[37mGET /_dash-layout HTTP/1.1e[0m" 200 -
2023-01-11 11:51:15,865 :: INFO :: 172.30.32.1 - - [11/Jan/2023 11:51:15] "e[37mGET /_dash-dependencies HTTP/1.1e[0m" 200 -
2023-01-11 11:51:15,945 :: INFO :: 172.30.32.1 - - [11/Jan/2023 11:51:15] "e[37mPOST /_dash-update-component HTTP/1.1e[0m" 200 -
2023-01-11 11:51:16,017 :: INFO :: 172.30.32.1 - - [11/Jan/2023 11:51:16] "e[37mGET /assets/images/settings.svg HTTP/1.1e[0m" 200 -
2023-01-11 11:51:16,033 :: INFO :: 172.30.32.1 - - [11/Jan/2023 11:51:16] "e[37mPOST /_dash-update-component HTTP/1.1e[0m" 200 -
2023-01-11 11:51:16,049 :: INFO :: 172.30.32.1 - - [11/Jan/2023 11:51:16] "e[37mPOST /_dash-update-component HTTP/1.1e[0m" 204 -
2023-01-11 11:51:16,075 :: INFO :: 172.30.32.1 - - [11/Jan/2023 11:51:16] "e[37mPOST /_dash-update-component HTTP/1.1e[0m" 204 -
2023-01-11 11:52:02,245 :: INFO :: Starting analysis on AndroidManifest.xml
2023-01-11 11:52:02,274 :: INFO :: Namespace mapping (60, 420) already seen! This is usually not a problem but could indicate packers or broken AXML compilers.
2023-01-11 11:52:02,276 :: INFO :: Namespace mapping (60, 420) already seen! This is usually not a problem but could indicate packers or broken AXML compilers.
2023-01-11 11:52:02,281 :: INFO :: Namespace mapping (60, 420) already seen! This is usually not a problem but could indicate packers or broken AXML compilers.
2023-01-11 11:52:02,284 :: INFO :: Namespace mapping (60, 420) already seen! This is usually not a problem but could indicate packers or broken AXML compilers.
2023-01-11 11:52:02,287 :: INFO :: Namespace mapping (60, 420) already seen! This is usually not a problem but could indicate packers or broken AXML compilers.
2023-01-11 11:52:02,289 :: INFO :: Namespace mapping (60, 420) already seen! This is usually not a problem but could indicate packers or broken AXML compilers.
2023-01-11 11:52:02,304 :: INFO :: Namespace mapping (60, 420) already seen! This is usually not a problem but could indicate packers or broken AXML compilers.
2023-01-11 11:52:02,306 :: INFO :: Namespace mapping (60, 420) already seen! This is usually not a problem but could indicate packers or broken AXML compilers.
2023-01-11 11:52:02,307 :: INFO :: Namespace mapping (60, 420) already seen! This is usually not a problem but could indicate packers or broken AXML compilers.
2023-01-11 11:52:02,311 :: INFO :: Namespace mapping (60, 420) already seen! This is usually not a problem but could indicate packers or broken AXML compilers.
2023-01-11 11:52:02,420 :: INFO :: APK file was successfully validated!
2023-01-11 11:52:02,423 :: WARNING :: Requested API level 31 is larger than maximum we have, returning API level 28 instead.
2023-01-11 11:52:18,658 :: INFO :: save config change
2023-01-11 11:52:19,985 :: INFO ::
Your vehicles: ["{'vin': 'VR3USxxxxxx', 'vehicle_id': 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx', 'label': '2008', 'brand': 'Peugeot', 'abrp_name': None, 'battery_power': 0, 'fuel_capacity': 44, 'max_elec_consumption': 70, 'max_fuel_consumption': 30}"]
2023-01-11 11:52:19,987 :: INFO :: save config change
2023-01-11 11:52:20,921 :: INFO :: ["{'vin': 'VR3USxxxxxxxxxxx', 'vehicle_id': 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx', 'label': '2008', 'brand': 'Peugeot', 'abrp_name': None, 'battery_power': 0, 'fuel_capacity': 44, 'max_elec_consumption': 70, 'max_fuel_consumption': 30}"]
2023-01-11 11:52:20,923 :: INFO :: save config change
2023-01-11 11:52:20,927 :: INFO :: 172.30.32.1 - - [11/Jan/2023 11:52:20] "e[37mPOST /_dash-update-component HTTP/1.1e[0m" 200 -
2023-01-11 11:52:41,919 :: INFO :: 172.30.32.1 - - [11/Jan/2023 11:52:41] "e[37mGET /config_otp HTTP/1.1e[0m" 200 -
2023-01-11 11:52:42,012 :: INFO :: 172.30.32.1 - - [11/Jan/2023 11:52:42] "e[37mGET /_dash-layout HTTP/1.1e[0m" 200 -
2023-01-11 11:52:42,031 :: INFO :: 172.30.32.1 - - [11/Jan/2023 11:52:42] "e[37mGET /_dash-dependencies HTTP/1.1e[0m" 200 -
Mais je ne reçois jamais le fameux SMS…
