Questions Epaper Waveshare / esp32
Je n’arrive pas à faire fonctionner correctement mon Epaper Waveshare avec mon esp32 (waveshare)
Voici mon code yaml :
esphome:
  friendly_name: EPAPER
  on_boot:
  - delay: 15s
  - script.execute: update_screen
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "//////////"
ota:
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esphome-Web-E0E4B0"
    password: "//////////"
captive_portal:
script:
  - id: update_screen
    then:
      - component.update: eink_display
spi:
  clk_pin: 13
  mosi_pin: 14
font:
  ######### REGULAR #################
  - file: "Fonts/GothamRnd-Book.ttf"
    glyphs: &font-glyphs
      ['!', '"', '%', '(', ')', '+', '=', ',', '-', '_', '.', ':', '°', ' ',
      '0', '1', '2', '3', '4', '5', '6', '7', '8', '9',
      'A', 'B', 'C', 'D', 'E', 'F', 'G', 'H', 'I', 'J', 'K', 'L', 'M', 'N', 'O', 'P', 'Q', 'R', 'S', 'T', 'U', 'V', 'W', 'X', 'Y', 'Z',
      'a', 'b', 'c', 'd', 'e', 'f', 'g', 'h', 'i', 'j', 'k', 'l', 'm', 'n', 'o', 'p', 'q', 'r', 's', 't', 'u', 'v', 'w', 'x', 'y', 'z',
      'é', 'à', 'è', 'ç', 'ù', 'É', 'À', 'È', 'Ç', 'Ù']
    glyphs : *font-glyphs
  ########## BOLD ##################
  - file: "Fonts/GothamRnd-Bold.ttf"
display:
  - platform: waveshare_epaper
    cs_pin: 15
    dc_pin: 27
    busy_pin: 25
    reset_pin: 26
    reset_duration: 2ms
    model: 7.50in
    rotation: 270°
    update_interval: never
    lambda: |
     it.filled_rectangle(50, 120, 380, 2);
     it.printf(20, 0, id(bold35), "X10 Y0");
Voici le lien vers mon équipement :
https://www.amazon.fr/gp/product/B075R69T93/
https://www.amazon.fr/Waveshare-Universal-Bluetooth-Wireless-Supports/dp/B07RM1BBVF/
Je pense que mon Epaper est une V1
Premier problème :
lorsque je lance les logs ou que j’installe la configuration, j’ai cette information qui apparait :
WARNING GPIO15 is a Strapping PIN and should be avoided.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
Je ne suis pas certain de bien comprendre ce que cela implique et comment le corriger (j’ai consulté la page indiquée).
Je me suis pourtant référé à la doc constructeur pour le pin out.
Quelqu’un d’entre vous pourrait-il éclairer ma lanterne ?
Deuxième problème :
Lorsque je charge la configuration sur l’ESP, voici que je je peux lire dans les logs :
Cela ne correspond pas à la définition de l’écran qui est de 800x480.
Ais-je raté quelque chose dans la configuration ?
Merci par avance pour l’aide que vous pourrez m’apporter.
version core-2023.10.3
python_version 3.11.5
os_version 6.1.56
arch x86_64
Installed Version 1.33.0
Available Repositories 1305
Downloaded Repositories 6
host_os Home Assistant OS 11.0
supervisor_version supervisor-2023.10.0
agent_version 1.6.0
docker_version 24.0.6
disk_total 38.7 GB
disk_used 9.8 GB
board ova
installed_addons Mosquitto broker (6.3.1), Zigbee2MQTT (1.33.1-1), Studio Code Server (5.11.0), File editor (5.6.0), Terminal & SSH (9.7.1), Node-RED (14.6.1), ESPHome (2023.9.3)
dashboards 1
resources 4
views 4
oldest_recorder_run 5 octobre 2023 à 20:14
current_recorder_run 14 octobre 2023 à 19:56
estimated_db_size 52.97 MiB
database_version 3.41.2
