J’ai le message ci-dessous quand j’essaye de mettre à jour via OTA mon dongle Zlinky_TIC via Zigbee2mqtt. Une idée de la raison ?
« release list.sort is not a function »
poste les journaux car la ca veux rien dire !!
C’est comme ci tu disais "je suis en panne ", sans donné de précision
Tu as raison ! J’ai une ribambelle de message du type
Zigbee2MQTT:info 2022-12-05 16:54:54: MQTT publish: topic 'zigbee2mqtt/Prise cellier', payload '{"current":null,"device_temperature":21,"energy":0.04,"linkquality":84,"power":0,"power_outage_memory":null,"state":"OFF","update":{"installed_version":"unknown","state":"idle"},"update_available":false,"voltage":null}'
Zigbee2MQTT:info 2022-12-05 16:54:55: MQTT publish: topic 'zigbee2mqtt/Prise bureau PC', payload '{"current":null,"device_temperature":15,"energy":0,"linkquality":102,"power":null,"power_outage_memory":null,"state":"OFF","update":{"installed_version":"unknown","state":"idle"},"update_available":false,"voltage":null}'
Zigbee2MQTT:info 2022-12-05 16:54:56: MQTT publish: topic 'zigbee2mqtt/Prise garage trottinette', payload '{"current":null,"device_temperature":12,"energy":0,"linkquality":75,"power":null,"power_outage_memory":null,"state":"OFF","update":{"installed_version":"unknown","state":"idle"},"update_available":false,"voltage":null}'
Zigbee2MQTT:info 2022-12-05 16:54:56: Checking if update available for 'Compteur Linky'
Zigbee2MQTT:info 2022-12-05 16:54:57: MQTT publish: topic 'zigbee2mqtt/bridge/response/device/ota_update/check', payload '{"data":{"id":"Compteur Linky"},"error":"Failed to check if update available for 'Compteur Linky' (releasesLIST.sort is not a function or its return value is not iterable)","status":"error","transaction":"495x6-1"}'
Zigbee2MQTT:error 2022-12-05 16:54:57: Failed to check if update available for 'Compteur Linky' (releasesLIST.sort is not a function or its return value is not iterable)
Zigbee2MQTT:info 2022-12-05 16:54:58: MQTT publish: topic 'zigbee2mqtt/Prise bureau chauffage', payload '{"current":null,"device_temperature":11,"energy":2.81,"linkquality":102,"power":0,"power_outage_memory":null,"state":"OFF","update":{"installed_version":"unknown","state":"idle"},"update_available":false,"voltage":null}'
Zigbee2MQTT:info 2022-12-05 16:54:59: MQTT publish: topic 'zigbee2mqtt/Prise bureau TV', payload '{"current":null,"device_temperature":15,"energy":0,"linkquality":66,"power":null,"power_outage_memory":null,"state":"OFF","update":{"installed_version":"unknown","state":"idle"},"update_available":false,"voltage":null}'
Zigbee2MQTT:info 2022-12-05 16:54:59: MQTT publish: topic 'zigbee2mqtt/Prise cellier', payload '{"current":null,"device_temperature":21,"energy":0.04,"linkquality":66,"power":0,"power_outage_memory":null,"state":"OFF","update":{"installed_version":"unknown","state":"idle"},"update_available":false,"voltage":null}'
Zigbee2MQTT:info 2022-12-05 16:55:00: MQTT publish: topic 'zigbee2mqtt/Prise bureau PC', payload '{"current":null,"device_temperature":15,"energy":0,"linkquality":96,"power":null,"power_outage_memory":null,"state":"OFF","update":{"installed_version":"unknown","state":"idle"},"update_available":false,"voltage":null}'
Zigbee2MQTT:info 2022-12-05 16:55:01: MQTT publish: topic 'zigbee2mqtt/Prise garage trottinette', payload '{"current":null,"device_temperature":12,"energy":0,"linkquality":60,"power":null,"power_outage_memory":null,"state":"OFF","update":{"installed_version":"unknown","state":"idle"},"update_available":false,"voltage":null}'
Zigbee2MQTT:info 2022-12-05 16:55:04: MQTT publish: topic 'zigbee2mqtt/Prise bureau chauffage', payload '{"current":null,"device_temperature":11,"energy":2.81,"linkquality":93,"power":0,"power_outage_memory":null,"state":"OFF","update":{"installed_version":"unknown","state":"idle"},"update_available":false,"voltage":null}'
Apres maj 11>12 j’ai vu entrer des milliers d’erreurs, entre 3h (redémarrage HA) et 17h plus de 900.000 (oui: neuf cents milles)… j’ai effacé le zlinky de z2m et re-appairé…maintenant bon
