Bonjour à tous
suite à la dernière mise à jour de HA vers 2022.2.4, l’intégration MQTT ne fonctionne plus (elle fonctionne depuis plus d’1 an).
exemple de Logs
Logger: homeassistant.components.switch
Source: components/mqtt/debug_info.py:82
Integration: Interrupteur (documentation, issues)
First occurred: 11:51:43 (14 occurrences)
Last logged: 11:51:54
Error adding entities for domain switch with platform mqtt
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 382, in async_add_entities
await asyncio.gather(*tasks)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 614, in _async_add_entity
await entity.add_to_platform_finish()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 778, in add_to_platform_finish
await self.async_added_to_hass()
File "/usr/src/homeassistant/homeassistant/components/mqtt/mixins.py", line 657, in async_added_to_hass
await super().async_added_to_hass()
File "/usr/src/homeassistant/homeassistant/components/mqtt/mixins.py", line 247, in async_added_to_hass
File "/usr/src/homeassistant/homeassistant/components/mqtt/mixins.py", line 320, in async_added_to_hass
File "/usr/src/homeassistant/homeassistant/components/mqtt/mixins.py", line 509, in async_added_to_hass
debug_info.add_entity_discovery_data(
File "/usr/src/homeassistant/homeassistant/components/mqtt/debug_info.py", line 82, in add_entity_discovery_data
debug_info = hass.data[DATA_MQTT_DEBUG_INFO]
KeyError: 'mqtt_debug_info'
|Version |core-2022.2.4
|Type d’installation |Home Assistant Container|
|Famille du système d’exploitation|Linux|
|Architecture du processeur|armv7l|
