Bonsoir,
Pour remplacer ma gateway xiaomi, j’ai voulu installer le dongle sonoff zigbee mais après 2 jours je n’arrive pas à appareiller quoi que se soit dans Z2M.
Voici les log que j’ai
info 2022-04-06 21:27:45: Logging to console and directory: '/config/zigbee2mqtt/log/2022-04-06.21-27-42' filename: log.txt
info 2022-04-06 21:27:45: Starting Zigbee2MQTT version 1.25.0 (commit #unknown)
info 2022-04-06 21:27:45: Starting zigbee-herdsman (0.14.20)
error 2022-04-06 21:28:51: Error while starting zigbee-herdsman
error 2022-04-06 21:28:51: Failed to start zigbee
error 2022-04-06 21:28:51: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
error 2022-04-06 21:28:51: Exiting...
error 2022-04-06 21:28:51: Error: network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby
at ZnpAdapterManager.beginCommissioning (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:347:23)
at ZnpAdapterManager.beginRestore (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:296:9)
at ZnpAdapterManager.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:80:17)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:123:29)
at Zigbee.start (/app/lib/zigbee.ts:58:27)
at Controller.start (/app/lib/controller.ts:100:27)
at start (/app/index.js:101:5)
Salut.
Juste pour être sur, tu as coupé la gateway ?
oui
j’ai reflashé le dongle et réinstallé Z2M, rien n’y fait pourtant la nouvelle version du firmware apparait dans Z2M.
Voici un nouvel exemple de logs
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] socat.sh: executing...
[22:15:43] INFO: Socat not enabled, marking service as down
[cont-init.d] socat.sh: exited 0.
[cont-init.d] zigbee2mqtt.sh: executing...
[cont-init.d] zigbee2mqtt.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[22:15:46] INFO: Handing over control to Zigbee2mqtt Core ...
> zigbee2mqtt@1.25.0 start
> node index.js
Zigbee2MQTT:info 07-04-2022 22:15:53: Logging to console and directory: '/config/zigbee2mqtt/log/2022-04-07.22-15-50' filename: log.txt
Zigbee2MQTT:info 07-04-2022 22:15:53: Starting Zigbee2MQTT version 1.25.0 (commit #unknown)
Zigbee2MQTT:info 07-04-2022 22:15:53: Starting zigbee-herdsman (0.14.20)
Zigbee2MQTT:error 07-04-2022 22:16:13: Error while starting zigbee-herdsman
Zigbee2MQTT:error 07-04-2022 22:16:13: Failed to start zigbee
Zigbee2MQTT:error 07-04-2022 22:16:13: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 07-04-2022 22:16:13: Exiting...
Zigbee2MQTT:error 07-04-2022 22:16:13: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:102:27)
[22:16:15] INFO: Handing over control to Zigbee2mqtt Core ...
> node index.js
Zigbee2MQTT:info 07-04-2022 22:16:22: Logging to console and directory: '/config/zigbee2mqtt/log/2022-04-07.22-16-19' filename: log.txt
Zigbee2MQTT:info 07-04-2022 22:16:22: Starting Zigbee2MQTT version 1.25.0 (commit #unknown)
Zigbee2MQTT:info 07-04-2022 22:16:22: Starting zigbee-herdsman (0.14.20)
Zigbee2MQTT:error 07-04-2022 22:16:42: Error while starting zigbee-herdsman
Zigbee2MQTT:error 07-04-2022 22:16:42: Failed to start zigbee
Zigbee2MQTT:error 07-04-2022 22:16:42: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 07-04-2022 22:16:42: Exiting...
Zigbee2MQTT:error 07-04-2022 22:16:43: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
[22:16:45] INFO: Handing over control to Zigbee2mqtt Core ...
> node index.js
Zigbee2MQTT:info 07-04-2022 22:16:52: Logging to console and directory: '/config/zigbee2mqtt/log/2022-04-07.22-16-49' filename: log.txt
Zigbee2MQTT:info 07-04-2022 22:16:52: Starting Zigbee2MQTT version 1.25.0 (commit #unknown)
Zigbee2MQTT:info 07-04-2022 22:16:52: Starting zigbee-herdsman (0.14.20)
Zigbee2MQTT:info 07-04-2022 22:16:54: zigbee-herdsman started (resumed)
Zigbee2MQTT:info 07-04-2022 22:16:54: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20220219,"transportrev":2},"type":"zStack3x0"}'
Zigbee2MQTT:info 07-04-2022 22:16:54: Currently 0 devices are joined:
Zigbee2MQTT:info 07-04-2022 22:16:54: Zigbee: disabling joining new devices.
Zigbee2MQTT:info 07-04-2022 22:16:54: Connecting to MQTT server at mqtt://192.168.1.1:1883
McFly
Avril 7, 2022, 8:25
4
Il voit pas ta clé sonoff si ?
McFly
Avril 7, 2022, 8:29
5
Je t’invite à mettre les infos de ton installation comme demandé lors de la création de ton post pour éviter des questions répétitives stp
As-tu récupéré le chemin de ta clé ?
Peux-tu partager ta config z2mqtt en enlevant les infos sensibles.
elle ne démarre pas au premier coup on dirait mais elle est reconnue au bout d’un moment
McFly
Avril 7, 2022, 8:30
7
tu es sous quel type d’installation ?
Si tu es en docker peux-tu forcer la version de z2mqtt en 1.24.0 et réssayer
voici ma config
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: '-d -d'
log: false
mqtt:
server: mqtt://192.xxx.x.x:1883
user: mqtt
password: mqtt
serial:
port: /dev/ttyUSB0
homeassistant: true
frontend:
port: 8099
host: 192.xxx.x.x
advanced:
homeassistant_legacy_entity_attributes: false
legacy_api: false
legacy_availability_payload: false
log_syslog:
app_name: Zigbee2MQTT
eol: /n
host: localhost
localhost: localhost
path: /dev/log
pid: process.pid
port: 123
protocol: tcp4
type: '5424'
timestamp_format: DD-MM-YYYY HH:mm:ss
device_options:
legacy: false
permit_join: true
je suis passé par les modules complémentaires
McFly
Avril 7, 2022, 9:18
10
Je ne crois pas que l’on puisse choisir la version.
Regarde dans la release note de zigbee2mqtt, il y a une mise jour a faire sur les cles cc2652.
Je l’ai reflashé mais toujours rien
McFly
Avril 9, 2022, 7:58
12
tu as que la cles USB de branché ? tu es sur un Raspberry ?
Non je tourne sur ssd en usb3
McFly
Avril 9, 2022, 8:22
14
avec alimentation supplémentaire ?
Non, je vais virer le ssd demain pour tester
Merci @McFly , la sulution est bien là. Le fait de repasser HA sur mSD à solutionner le pb. Maintenant il me faut trouver un system pour mon SSD.
ouvrir un thread d’il y a 2 ans pour une autre problématique… quel intérêt ??
