System Health
version | 2021.1.5 |
dev | false |
hassio | true |
docker | true |
virtualenv | false |
python_version | 3.8.7 |
os_name | Linux |
os_version | 5.4.86 |
arch | x86_64 |
timezone | Europe/Paris |
GitHub API | ok |
Github API Calls Remaining | 4948 |
Installed Version | 1.10.1 |
Stage | running |
Available Repositories | 709 |
Installed Repositories | 4 |
logged_in | false |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | ok |
Hass.io
host_os | Home Assistant OS 5.10 |
update_channel | stable |
supervisor_version | 2021.01.7 |
docker_version | 19.03.13 |
disk_total | 30.8 GB |
disk_used | 6.8 GB |
healthy | true |
supported | true |
board | ova |
supervisor_api | ok |
version_api | ok |
installed_addons | Terminal & SSH (8.10.0), Samba share (9.3.0), Check Home Assistant configuration (3.6.0), File editor (5.2.0), ESPHome (1.15.3), Home Panel (1.8.3), Mosquitto broker (5.1) |
Lovelace
dashboards | 1 |
mode | storage |
views | 1 |
resources | 0 |
Petit soucis pour configurer un detecteur de mouvement « sonoff » connecté sur la passerelle sonoff rf433.
Sur la doc de « SonoffLan » il donne l’exemple :
Citation PIR Sensor
sonoff:
rfbridge:
PIR Sensor 1: # sensor name in eWeLink application
device_class: motion
timeout: 60 # optional (default 120), timeout in seconds for auto turn off
PIR Sensor 2: # sensor name in eWeLink application
si je colle ce pavé comme ceci :
# sonoff #
sonoff:
username: !secret ewelink_user
password: !secret ewelink_pwd
mode: cloud
sonoff:
rfbridge:
PIR Sensor 1: Détecteur presence garage
timeout: 60
lors du control de configuration j’ai
Error loading /config/configuration.yaml: mapping values are not allowed here
in « /config/configuration.yaml », line 42, column 19
qui correspond a : device_class: motion
Comprend pô
*Merci a vous
