bonjour
j ai réussi a integrer 15 peripherique tuya sans soucis en local
par contre il m en reste une dizaine que j y arrive pas j ai toutes les infos et au moment de le faire j ai l erreur
je suis novice et je comprends pas malgre le log
merci de votre aide
Cette erreur provient d'une intégration personnalisée
Logger: custom_components.localtuya.common
Source: custom_components/localtuya/pytuya/__init__.py:247
Integration: LocalTuya integration (documentation, issues)
First occurred: 27 août 2022 à 17:02:10 (1043 occurrences)
Last logged: 13:17:17
[bff...bkp] Connect to 192.168.1.16 failed
[bfb...ly1] Connect to 192.168.1.123 failed
[bfc...eee] Connect to 192.168.1.48 failed
[bf0...aeu] Connect to 192.168.1.173 failed
[bf4...vdt] Connect to 192.168.1.89 failed
File "/usr/local/lib/python3.10/asyncio/locks.py", line 390, in acquire
await fut
asyncio.exceptions.CancelledError
File "/usr/local/lib/python3.10/asyncio/tasks.py", line 456, in wait_for
return fut.result()
The above exception was the direct cause of the following exception:
File "/config/custom_components/localtuya/common.py", line 170, in _make_connection
status = await self._interface.status()
File "/config/custom_components/localtuya/pytuya/__init__.py", line 481, in status
status = await self.exchange(STATUS)
File "/config/custom_components/localtuya/pytuya/__init__.py", line 460, in exchange
msg = await self.dispatcher.wait_for(seqno)
File "/config/custom_components/localtuya/pytuya/__init__.py", line 247, in wait_for
await asyncio.wait_for(self.listeners[seqno].acquire(), timeout=timeout)
File "/usr/local/lib/python3.10/asyncio/tasks.py", line 458, in wait_for
raise exceptions.TimeoutError() from exc
asyncio.exceptions.TimeoutError
Renseigner votre problème
version |
core-2022.8.7 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.10.5 |
os_name |
Linux |
os_version |
5.15.60 |
arch |
x86_64 |
timezone |
Europe/Brussels |
config_dir |
/config |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
GitHub API Calls Remaining |
5000 |
Installed Version |
1.27.0 |
Stage |
running |
Available Repositories |
1101 |
Downloaded Repositories |
31 |
AccuWeather
can_reach_server |
ok |
remaining_requests |
46 |
logged_in |
true |
subscription_expiration |
31 août 2022 à 02:00 |
relayer_connected |
true |
remote_enabled |
true |
remote_connected |
true |
alexa_enabled |
true |
google_enabled |
true |
remote_server |
eu-central-1-0.ui.nabu.casa |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 8.5 |
update_channel |
stable |
supervisor_version |
supervisor-2022.08.3 |
agent_version |
1.2.1 |
docker_version |
20.10.14 |
disk_total |
30.8 GB |
disk_used |
11.2 GB |
healthy |
true |
supported |
true |
board |
ova |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
File editor (5.3.3), Example (5.1.1), Terminal & SSH (9.6.0), Home Assistant Google Drive Backup (0.108.4), Studio Code Server (5.3.0), Spotify Connect (0.12.2) |
dashboards |
8 |
resources |
16 |
views |
10 |
mode |
storage |
oldest_recorder_run |
18 août 2022 à 11:29 |
current_recorder_run |
27 août 2022 à 17:01 |
estimated_db_size |
904.51 MiB |
database_engine |
sqlite |
database_version |
3.38.5 |
Sonoff
version |
3.1.0 (3871c0b) |
cloud_online |
3 / 3 |
local_online |
3 / 3 |
Spotify
api_endpoint_reachable |
ok |
Tu n’as pas mis les bonnes ip ou bien elles ont changées depuis
bonjour pulpy
si c est bien celle que j ai je les ai aussi sous jeedom comme tu me connais et elle fonctionne avec cet ip et quand je verifie sur mon prog d ip elle sont bien la aussi et connectée
Dans ce cas c’est que tu as un souci réseau : HA ne sait pas se connecter à ces ip
c est bizzare qu il se connecte a tous les autres sauf ceux la
je pense essayer d en reappairer une de zero pour voir mais je demandais avant si quelqu un avait une idée comme dit hier
