Unable to connect to the MQTT broker: Connection Refused: not authorised
voila les logs de mosquitto:
1654967613: Saving in-memory database to /data//mosquitto.db.
1654967694: New connection from 172.30.32.2:54880 on port 1883.
1654967694: Client <unknown> closed its connection.
1654967709: New connection from 172.30.32.1:52145 on port 1883.
1654967709: Client <unknown> disconnected, not authorised.
1654967790: New connection from 172.30.32.1:47329 on port 1883.
1654967790: Client <unknown> disconnected, not authorised.
1654967792: New connection from 172.30.32.1:56861 on port 1883.
1654967792: Client <unknown> disconnected, not authorised.
1654967794: New connection from 172.30.32.1:59979 on port 1883.
1654967794: Client <unknown> disconnected, not authorised.
1654967798: New connection from 172.30.32.1:59267 on port 1883.
1654967798: Client <unknown> disconnected, not authorised.
1654967807: New connection from 172.30.32.1:46231 on port 1883.
1654967807: Client <unknown> disconnected, not authorised.
1654967814: New connection from 172.30.32.2:54882 on port 1883.
1654967814: Client <unknown> closed its connection.
1654967823: New connection from 172.30.32.1:39783 on port 1883.
1654967823: Client <unknown> disconnected, not authorised.
1654967855: New connection from 172.30.32.1:38457 on port 1883.
1654967855: Client <unknown> disconnected, not authorised.
1654967898: Client tasmota_48D34B closed its connection.
1654967902: New connection from 192.168.92.216:61528 on port 1883.
1654967902: New client connected from 192.168.92.216:61528 as tasmota_48D34B (p2, c1, k30, u'mqtt_user').
1654967919: New connection from 172.30.32.1:43439 on port 1883.
1654967919: Client <unknown> disconnected, not authorised.
1654967934: New connection from 172.30.32.2:54884 on port 1883.
1654967934: Client <unknown> closed its connection.
1654968019: Client tasmota_48D34B closed its connection.
1654968024: New connection from 192.168.92.216:60449 on port 1883.
1654968024: Client <unknown> disconnected, not authorised.
1654968035: New connection from 192.168.92.216:58173 on port 1883.
1654968035: Client <unknown> disconnected, not authorised.
1654968039: New connection from 172.30.32.1:39937 on port 1883.
1654968039: Client <unknown> disconnected, not authorised.
1654968054: New connection from 172.30.32.2:54886 on port 1883.
1654968054: Client <unknown> closed its connection.
1654968056: New connection from 192.168.92.216:52445 on port 1883.
1654968056: Client <unknown> disconnected, not authorised.
1654968066: New connection from 192.168.92.216:53646 on port 1883.
1654968066: New client connected from 192.168.92.216:53646 as tasmota_48D34B (p2, c1, k30, u'mqtt_user').
1654968159: New connection from 172.30.32.1:42183 on port 1883.
1654968159: Client <unknown> disconnected, not authorised.
1654968174: New connection from 172.30.32.2:54888 on port 1883.
1654968174: Client <unknown> closed its connection.
et zigbee2mqtt
Zigbee2MQTT:info  2022-06-11 19:55:48: MQTT publish: topic 'zigbee2mqtt/Prise 0cec6', payload '{"current":0,"energy":0.23,"linkquality":108,"power":0,"state":"ON","voltage":236.94}'
zlinky config: historique, single_phase, false, BASE
Zigbee2MQTT:info  2022-06-11 19:56:17: MQTT publish: topic 'zigbee2mqtt/Salle de bains', payload '{"battery":34,"humidity":52.35,"linkquality":144,"temperature":24.82,"voltage":2600}'
Zigbee2MQTT:info  2022-06-11 19:56:17: MQTT publish: topic 'zigbee2mqtt/Salle de bains', payload '{"battery":34,"humidity":53.27,"linkquality":147,"temperature":24.82,"voltage":2600}'
Zigbee2MQTT:info  2022-06-11 19:56:18: MQTT publish: topic 'zigbee2mqtt/Prise 0cec6', payload '{"current":0,"energy":0.23,"linkquality":102,"power":0,"state":"ON","voltage":236.83}'
Zigbee2MQTT:info  2022-06-11 19:56:28: MQTT publish: topic 'zigbee2mqtt/ZLinky', payload '{"active_register_tier_delivered":"TH..","apparent_power":770,"available_power":30,"current_summ_delivered":13266,"current_tarif":"BASE","linkquality":99,"meter_serial_number":"062061183053","rms_current":3,"rms_current_max":90,"update":{"state":"idle"},"update_available":false,"warn_d_p_s":30}'
Zigbee2MQTT:info  2022-06-11 19:56:33: MQTT publish: topic 'zigbee2mqtt/Prise 0cec6', payload '{"current":0,"energy":0.23,"linkquality":99,"power":0,"state":"ON","voltage":236.87}'
Zigbee2MQTT:info  2022-06-11 19:56:37: MQTT publish: topic 'zigbee2mqtt/Detecteur Incendie', payload '{"alarm":null,"battery":100,"battery_low":false,"current_firmware":"4.0.2","enrolled":true,"fault":false,"ias_cie_address":"0x00124b0024c918ac","linkquality":135,"max_duration":20,"reliability":"no_fault_detected","restore_reports":true,"smoke":false,"supervision_reports":true,"temperature":24.75,"test":false,"update":{"state":"idle"},"update_available":false,"voltage":3000,"zone_id":23}'
Zigbee2MQTT:info  2022-06-11 19:56:48: MQTT publish: topic 'zigbee2mqtt/Prise 0cec6', payload '{"current":0,"energy":0.23,"linkquality":102,"power":0,"state":"ON","voltage":237.79}'
Zigbee2MQTT:info  2022-06-11 19:56:52: MQTT publish: topic 'zigbee2mqtt/Capteur Hygrometrie et Temperature', payload '{"battery":99,"humidity":54.5,"linkquality":102,"temperature":null}'
Zigbee2MQTT:info  2022-06-11 19:57:03: MQTT publish: topic 'zigbee2mqtt/Prise 0cec6', payload '{"current":0,"energy":0.23,"linkquality":99,"power":0,"state":"ON","voltage":237.43}'
Zigbee2MQTT:info  2022-06-11 19:57:07: MQTT publish: topic 'zigbee2mqtt/ZLinky', payload '{"active_register_tier_delivered":"TH..","apparent_power":790,"available_power":30,"current_summ_delivered":13266,"current_tarif":"BASE","linkquality":96,"meter_serial_number":"062061183053","rms_current":3,"rms_current_max":90,"update":{"state":"idle"},"update_available":false,"warn_d_p_s":30}'
Zigbee2MQTT:info  2022-06-11 19:57:08: MQTT publish: topic 'zigbee2mqtt/Prise 0cec6', payload '{"current":0,"energy":0.23,"linkquality":102,"power":0,"state":"ON","voltage":237.47}'
Zigbee2MQTT:info  2022-06-11 19:57:28: MQTT publish: topic 'zigbee2mqtt/Prise 0cec6', payload '{"current":0,"energy":0.23,"linkquality":114,"power":0,"state":"ON","voltage":236.9}'
Zigbee2MQTT:info  2022-06-11 19:57:29: MQTT publish: topic 'zigbee2mqtt/ZLinky', payload '{"active_register_tier_delivered":"TH..","apparent_power":790,"available_power":30,"current_summ_delivered":13266,"current_tarif":"BASE","linkquality":99,"meter_serial_number":"062061183053","rms_current":6,"rms_current_max":90,"update":{"state":"idle"},"update_available":false,"warn_d_p_s":30}'
Zigbee2MQTT:info  2022-06-11 19:57:33: MQTT publish: topic 'zigbee2mqtt/Prise 0cec6', payload '{"current":0,"energy":0.23,"linkquality":117,"power":0,"state":"ON","voltage":236.8}'
Zigbee2MQTT:info  2022-06-11 19:57:52: MQTT publish: topic 'zigbee2mqtt/ZLinky', payload '{"active_register_tier_delivered":"TH..","apparent_power":790,"available_power":30,"current_summ_delivered":13266,"current_tarif":"BASE","linkquality":105,"meter_serial_number":"062061183053","rms_current":6,"rms_current_max":90,"update":{"state":"idle"},"update_available":false,"warn_d_p_s":30}'
Zigbee2MQTT:info  2022-06-11 19:57:53: MQTT publish: topic 'zigbee2mqtt/Prise 0cec6', payload '{"current":0,"energy":0.23,"linkquality":81,"power":0,"state":"ON","voltage":236.55}'
Zigbee2MQTT:info  2022-06-11 19:58:28: MQTT publish: topic 'zigbee2mqtt/Prise 0cec6', payload '{"current":0,"energy":0.23,"linkquality":117,"power":0,"state":"ON","voltage":237.83}'
Zigbee2MQTT:info  2022-06-11 19:58:31: MQTT publish: topic 'zigbee2mqtt/ZLinky', payload '{"active_register_tier_delivered":"TH..","apparent_power":770,"available_power":30,"current_summ_delivered":13266,"current_tarif":"BASE","linkquality":84,"meter_serial_number":"062061183053","rms_current":6,"rms_current_max":90,"update":{"state":"idle"},"update_available":false,"warn_d_p_s":30}'
Zigbee2MQTT:info  2022-06-11 19:58:48: MQTT publish: topic 'zigbee2mqtt/Prise 0cec6', payload '{"current":0,"energy":0.23,"linkquality":123,"power":0,"state":"ON","voltage":236.65}'
Zigbee2MQTT:info  2022-06-11 19:58:49: MQTT publish: topic 'zigbee2mqtt/ZLinky', payload '{"active_register_tier_delivered":"TH..","apparent_power":770,"available_power":30,"current_summ_delivered":13266,"current_tarif":"BASE","linkquality":90,"meter_serial_number":"062061183053","rms_current":3,"rms_current_max":90,"update":{"state":"idle"},"update_available":false,"warn_d_p_s":30}'
Zigbee2MQTT:info  2022-06-11 19:59:13: MQTT publish: topic 'zigbee2mqtt/Prise 0cec6', payload '{"current":0,"energy":0.23,"linkquality":114,"power":0,"state":"ON","voltage":237.15}'
Zigbee2MQTT:info  2022-06-11 19:59:16: MQTT publish: topic 'zigbee2mqtt/ZLinky', payload '{"active_register_tier_delivered":"TH..","apparent_power":770,"available_power":30,"current_summ_delivered":13266,"current_tarif":"BASE","linkquality":102,"meter_serial_number":"062061183053","rms_current":3,"rms_current_max":90,"update":{"state":"idle"},"update_available":false,"warn_d_p_s":30}'
Zigbee2MQTT:info  2022-06-11 19:59:18: MQTT publish: topic 'zigbee2mqtt/Prise 0cec6', payload '{"current":0,"energy":0.23,"linkquality":117,"power":0,"state":"ON","voltage":237.54}'
Zigbee2MQTT:info  2022-06-11 19:59:52: MQTT publish: topic 'zigbee2mqtt/Bouilloire', payload '{"linkquality":39,"state":"OFF"}'
Zigbee2MQTT:info  2022-06-11 19:59:53: MQTT publish: topic 'zigbee2mqtt/Prise 0cec6', payload '{"current":0,"energy":0.23,"linkquality":114,"power":0,"state":"ON","voltage":237.72}'
Zigbee2MQTT:info  2022-06-11 19:59:56: MQTT publish: topic 'zigbee2mqtt/ZLinky', payload '{"active_register_tier_delivered":"TH..","apparent_power":780,"available_power":30,"current_summ_delivered":13266,"current_tarif":"BASE","linkquality":105,"meter_serial_number":"062061183053","rms_current":3,"rms_current_max":90,"update":{"state":"idle"},"update_available":false,"warn_d_p_s":30}'
Zigbee2MQTT:info  2022-06-11 19:59:58: MQTT publish: topic 'zigbee2mqtt/Prise 0cec6', payload '{"current":0,"energy":0.23,"linkquality":126,"power":0,"state":"ON","voltage":237.58}'
Zigbee2MQTT:info  2022-06-11 20:00:03: MQTT publish: topic 'zigbee2mqtt/Capteur Toilettes', payload '{"battery":null,"humidity":46.17,"linkquality":135,"temperature":25.79,"voltage":null}'
Zigbee2MQTT:info  2022-06-11 20:00:03: MQTT publish: topic 'zigbee2mqtt/Capteur Toilettes', payload '{"battery":null,"humidity":46.41,"linkquality":135,"temperature":25.79,"voltage":null}'
Zigbee2MQTT:info  2022-06-11 20:00:13: MQTT publish: topic 'zigbee2mqtt/Prise 0cec6', payload '{"current":0,"energy":0.23,"linkquality":123,"power":0,"state":"ON","voltage":237.72}'
Zigbee2MQTT:info  2022-06-11 20:00:18: MQTT publish: topic 'zigbee2mqtt/Prise 0cec6', payload '{"current":0,"energy":0.23,"linkquality":126,"power":0,"state":"ON","voltage":237.79}'
Zigbee2MQTT:info  2022-06-11 20:00:39: MQTT publish: topic 'zigbee2mqtt/ZLinky', payload '{"active_register_tier_delivered":"TH..","apparent_power":780,"available_power":30,"current_summ_delivered":13266,"current_tarif":"BASE","linkquality":105,"meter_serial_number":"062061183053","rms_current":3,"rms_current_max":90,"update":{"state":"idle"},"update_available":false,"warn_d_p_s":30}'
Zigbee2MQTT:info  2022-06-11 20:01:33: MQTT publish: topic 'zigbee2mqtt/Prise 0cec6', payload '{"current":0,"energy":0.23,"linkquality":111,"power":0,"state":"ON","voltage":237.29}'
Zigbee2MQTT:info  2022-06-11 20:01:37: MQTT publish: topic 'zigbee2mqtt/Detecteur Incendie', payload '{"alarm":null,"battery":100,"battery_low":false,"current_firmware":"4.0.2","enrolled":true,"fault":false,"ias_cie_address":"0x00124b0024c918ac","linkquality":66,"max_duration":20,"reliability":"no_fault_detected","restore_reports":true,"smoke":false,"supervision_reports":true,"temperature":24.75,"test":false,"update":{"state":"idle"},"update_available":false,"voltage":3000,"zone_id":23}'
Zigbee2MQTT:info  2022-06-11 20:01:47: MQTT publish: topic 'zigbee2mqtt/ZLinky', payload '{"active_register_tier_delivered":"TH..","apparent_power":790,"available_power":30,"current_summ_delivered":13266,"current_tarif":"BASE","linkquality":96,"meter_serial_number":"062061183053","rms_current":3,"rms_current_max":90,"update":{"state":"idle"},"update_available":false,"warn_d_p_s":30}'
Zigbee2MQTT:info  2022-06-11 20:01:58: MQTT publish: topic 'zigbee2mqtt/Prise 0cec6', payload '{"current":0,"energy":0.23,"linkquality":99,"power":0,"state":"ON","voltage":237.54}'
Zigbee2MQTT:info  2022-06-11 20:02:00: MQTT publish: topic 'zigbee2mqtt/Presence Placard', payload '{"battery":100,"battery_low":false,"linkquality":135,"occupancy":true,"tamper":false,"voltage":3000}'
