Mmh… j’ai une erreur lorsque je coche la case « Create entity » et que j’exécute la commande.
La commande est pourtant bien exécutée (le volet s’ouvre ou se ferme)
2022-09-09 13:28:59.182 ERROR (MainThread) [homeassistant.helpers.script.websocket_api_script] websocket_api script: Error executing script. Unexpected error for call_service at pos 1: 'command'
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 447, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 680, in _async_call_service_step
await service_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1738, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1775, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/config/custom_components/rfplayer/__init__.py", line 110, in async_send_command
await hass.data[DOMAIN][DATA_DEVICE_REGISTER][EVENT_KEY_COMMAND](device)
KeyError: 'command'
2022-09-09 13:28:59.183 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [140672464016512] Error handling message: Unknown error (unknown_error)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 27, in _handle_async_response
await func(hass, connection, msg)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 647, in handle_execute_script
await script_obj.async_run(msg.get("variables"), context=context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1513, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 405, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 449, in _async_step
self._handle_exception(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 472, in _handle_exception
raise exception
await service_task
task.result()
KeyError: 'command'
Ca te parle ?
