Utilisateur Rfplayer
Bjr …
Je cherche des utilisateurs du Rfplayer sous HA.
Est-ce que @Aohzan est toujours sur son évolution ?
Je vois que dans les logs, certains infos ne sont pas prisent au bon endroit (sonde) ,l’info est celle du type et non celle de la value des t°…
un log sonde pour info !
2022-01-12 10:42:57 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-37", "floorNoise": "-92", "rfQuality": "10", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "4", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0x1A2D", "id_PHYMeaning": "THGR122/228/238/268,THGN122/123/132", "adr_channel": "49412",  "adr": "193",  "channel": "4",  "qualifier": "32",  "lowBatt": "0", "measures" : [{"type" : "temperature", "value" : "+18.2", "unit" : "Celsius"},
2022-01-12 10:42:57 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: {"type" : "hygrometry", "value" : "69", "unit" : "%"}]}}}
2022-01-12 10:42:57 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] decoded packet: {'node': 'gateway', 'protocol': 'OREGON', 'id': None, 'command': '0'}
2022-01-12 10:42:57 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpparser] f:node,v:gateway
2022-01-12 10:42:57 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpparser] f:protocol,v:OREGON
2022-01-12 10:42:57 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpparser] f:id,v:None
2022-01-12 10:42:57 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpparser] f:command,v:0
2022-01-12 10:42:57 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpparser] event: command -> 0
2022-01-12 10:42:57 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpparser] packet_events, sensor:command,value:0
2022-01-12 10:42:57 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] ignore_event
2022-01-12 10:42:57 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] got event: {'id': 'OREGON_cmd', 'sensor': 'command', 'value': '0', 'unit': None}
2022-01-12 10:42:57 DEBUG (MainThread) [custom_components.rfplayer] event of type sensor: {'id': 'OREGON_cmd', 'sensor': 'command', 'value': '0', 'unit': None}
2022-01-12 10:42:57 DEBUG (MainThread) [custom_components.rfplayer] passing event to sensor.oregon_cmd
Je comprend bien que cet addon n’est pas reprise en officiel …
Enr egardant de plus prés les infos du plugin je vois bien que seul certains protocoles sont reconnus d’ou la valeur remontée …
if data["protocol"] in ["BLYSS", "CHACON"]:
J’ai fait une maj assez récemment, normalement tu peux envoyer des commandes sur n’importe quel protocole, c’est juste que s’il y en a qui se comportent de façon spécifique il seront pas ou mal traité, dans ce cas là il faut me fournir les logs en debug pour que je puisse intégrer ça
D’abord je vois que tu es sur le Forum fr , un bon point pour nous !
Le truc c’est pour un protocole qui n’a pas de commande seulement des infos, je vois bien que tu n’as pas implémenté ce type de protocole et j’aimerais simplement savoir si tu pense le faire !
pour les logs pas de « blem » tu as celui d’une sonde au-dessus, sinon je t’en renvoi d’autres au besoin …
Merci @+DÕ¿ÕM
J’avais pas fait attention, ça devrait suffire en effet, je te tiens au courant
Un autre protocole celui EDISIO en 868
Je ne sais pas si tu connais le protocole EDISIOFRAME ?, mais je vais regarder comment tu fais la commande pour les EDISIO 868
mais je te donne l'info d'un capteur Edisio T° en attendant
2022-01-12 13:18:26 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-61", "floorNoise": "-94", "rfQuality": "8", "protocol": "16", "protocolMeaning": "EDISIO", "infoType": "15", "frequency": "868350"},"infos": {"subType": "25", "subTypeMeaning": "SET_TEMPERATURE", "id": "3289809396", "qualifier": "2", "info": "9224", "infoMeaning": "ETS-100, 3.6V", "add0": "1887", "add1": "0"}}}
2022-01-12 13:18:26 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] decoded packet: {'node': 'gateway', 'protocol': 'EDISIO', 'id': '3289809396', 'command': '25'}
2022-01-12 13:18:26 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpparser] f:node,v:gateway
2022-01-12 13:18:26 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpparser] f:protocol,v:EDISIO
2022-01-12 13:18:26 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpparser] f:id,v:3289809396
2022-01-12 13:18:26 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpparser] f:command,v:25
2022-01-12 13:18:26 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpparser] event: command -> 25
2022-01-12 13:18:26 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpparser] packet_events, sensor:command,value:25
2022-01-12 13:18:26 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] ignore_event
2022-01-12 13:18:26 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] got event: {'id': 'EDISIO_3289809396_cmd', 'sensor': 'command', 'value': '25', 'unit': None}
2022-01-12 13:18:26 DEBUG (MainThread) [custom_components.rfplayer] event of type sensor: {'id': 'EDISIO_3289809396_cmd', 'sensor': 'command', 'value': '25', 'unit': None}
2022-01-12 13:18:26 DEBUG (MainThread) [custom_components.rfplayer] passing event to sensor.edisio_3289809396
On a maintenant un plugin pour Hass ?
Quelqu’un l’a déjà essayé avec une alarme deltadore ?
merci :slight_smile:
Je suis un nouvel utilisateur de RFPLayer sous HA, j’avais hâte que cette intégration arrive, je l’utilisais sous Jeedom.
Entre temps, je me suis acheté un pont RF de chez Sonoff le R2v2 et je l’ai modifié pour pouvoir l’intégrer. Le protocole Chacon ne semble pas fonctionner. Du coup j’ai cherché de nouveau si l’intégration avait évolué et je suis arrivé sur ce poste et le github de GCE-Electronics et miracle, l’integration (un début) est là !!!
J’ai 4 volets commandés par des modules DIO, je souhaite les commander avec HA, ça fonctionne pour un, mais j’ai un bug pour les autres, ça semble lié à l’enregistrement d’une entité lorsque j’appelle le service. J’ai ouvert un ticket sur la plateforme Github.
En tout cas c’est super cool de voir enfin cette intégration arrivée, merci à @Aohzan pour son travail.
Christophe
Hello, j’ai vu l’issue, je regarderai ça en même temps, je vous promets rien niveau délais :disappointed:
Mais aucun problème pour le délais :slight_smile:
Je ne suis pas dans l’urgence, et merci encore pour ton travail.
Christophe
