Bonjour tout le monde,
Je rencontre un souci depuis quelques jours avec mon capteur énergie, par moment, j’ai une valeur de + 76 000 000 kwh dont j’ignore l’origine.
Mon capteur est un homemade sur un esp32 configurer avec esphome.
J’avais eu le tour pour une valeur à 0 que j’ai pu filtrer, mais pour ce problème est-il possible de filtrer les valeurs supérieures ?
uart:
rx_pin: GPIO3
# tx_pin: GPIO1
baud_rate: 1200
parity: EVEN
data_bits: 7
teleinfo:
update_interval: 5s
historical_mode: true
binary_sensor:
- platform: status
- platform: wifi_signal
update_interval: 60s
unit_of_measurement: dB
accuracy_decimals: 0
force_update: false
icon: mdi:wifi
- platform: uptime
unit_of_measurement: s
force_update: false
icon: mdi:timer
- platform: teleinfo
tag_name: "ADCO"
unit_of_measurement: ""
icon: mdi:barcode
tag_name: "IINST"
unit_of_measurement: "A"
icon: mdi:current-ac
tag_name: "ISOUSC"
name: "Intensité souscrite"
tag_name: "IMAX"
name: "Intensité maximale appelée"
tag_name: "PAPP"
unit_of_measurement: "VA"
icon: mdi:flash
# - platform: teleinfo
# tag_name: "BASE"
# id: base
# name: "Teleinfo index_base_kwh"
# unit_of_measurement: "kWh"
# device_class: "energy"
# state_class: "total_increasing"
# accuracy_decimals: 3
# filters:
# - filter_out: 0
# - multiply: 0.001
# icon: mdi:gauge
tag_name: "HCHC"
name: "Index heures creuses"
filters:
- filter_out: 0
- multiply: 0.001
icon: mdi:gauge
tag_name: "HCHP"
name: "Index heures pleines"
filters:
- filter_out: 0
- multiply: 0.001
icon: mdi:gauge
button:
- platform: restart
text_sensor:
tag_name: "PTEC"
icon: mdi:clock-time-nine-outline
icon: mdi:clock-start
lambda: |-
int seconds = (id(uptime_seconds).state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
if ( days ) {
return { (String(days) +"d " + String(hours) +"h " + String(minutes) +"m "+ String(seconds) +"s").c_str() };
} else if ( hours ) {
return { (String(hours) +"h " + String(minutes) +"m "+ String(seconds) +"s").c_str() };
} else if ( minutes ) {
return { (String(minutes) +"m "+ String(seconds) +"s").c_str() };
} else {
return { (String(seconds) +"s").c_str() };
tag_name: "OPTARIF"
name: "Type d'abonnement"
icon: mdi:handshake
tag_name: "PTEC"
name: "Tarif en cours"
Merci pour vos réponces.
[center]## System Information
version | core-2023.1.7 |
dev | false |
hassio | true |
docker | true |
user | root |
virtualenv | false |
python_version | 3.10.7 |
os_name | Linux |
os_version | 5.15.80 |
arch | x86_64 |
timezone | Europe/Paris |
config_dir | /config |
GitHub API | ok |
GitHub Content | ok |
GitHub Web | ok |
GitHub API Calls Remaining | 5000 |
Installed Version | 1.30.0 |
Stage | running |
Available Repositories | 1200 |
Downloaded Repositories | 29 |
logged_in | false |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | ok |
host_os | Home Assistant OS 9.4 |
update_channel | stable |
supervisor_version | supervisor-2023.01.1 |
agent_version | 1.4.1 |
docker_version | 20.10.19 |
disk_total | 30.8 GB |
disk_used | 14.2 GB |
healthy | true |
supported | true |
board | ova |
supervisor_api | ok |
version_api | ok |
installed_addons | Samba share (10.0.0), File editor (5.5.0), Studio Code Server (5.5.2), Terminal & SSH (9.6.1), Xiaomi Mi Scale (0.3.6), ESPHome (2022.12.6), Let’s Encrypt (4.12.8), Samba Backup (5.2.0), Log Viewer (0.14.0), AppDaemon (0.11.0), FTP (4.6.2), RPC Shutdown (2.2), SSH & Web Terminal (13.0.2), Mosquitto broker (6.1.3), MariaDB (2.5.1), phpMyAdmin (0.8.3), SQLite Web (3.7.0) |
dashboards | 1 |
resources | 20 |
views | 7 |
mode | storage |
oldest_recorder_run | 22 janvier 2023 à 06:34 |
current_recorder_run | 27 janvier 2023 à 18:10 |
estimated_db_size | 363.27 MiB |
database_engine | mysql |
database_version | 10.6.8 |
