Comment faire l’update du firware Shelly Door 2, cet appareil se met en veille lorsqu’il n’est pas utilisé.
Du coup l’adresse IP local est inaccessible en continu.
System Health
version |
core-2021.9.6 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.9.6 |
os_name |
Linux |
os_version |
5.10.17-v8 |
arch |
aarch64 |
timezone |
Europe/Paris |
GitHub API |
ok |
Github API Calls Remaining |
4973 |
Installed Version |
1.15.2 |
Stage |
running |
Available Repositories |
881 |
Installed Repositories |
2 |
logged_in |
false |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 6.3 |
update_channel |
stable |
supervisor_version |
supervisor-2021.09.0 |
docker_version |
20.10.7 |
disk_total |
14.1 GB |
disk_used |
7.4 GB |
healthy |
true |
supported |
true |
board |
rpi3-64 |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
Check Home Assistant configuration (3.8.0), File editor (5.3.3), Terminal & SSH (9.1.3), Z-Wave JS (0.1.40), Node-RED (10.0.0), Duck DNS (1.13.0), Google Assistant SDK (2.5.0), MariaDB (2.4.0) |
Lovelace
dashboards |
1 |
resources |
0 |
views |
3 |
mode |
storage |
