bonsoir,
Ayant une Xiaomi Gateway 3 sous la main je me suis amusé à la bricoler.
J’ai réussi à intégrer des appareils via ZHA mais je n’arrive pas démarrer le module complémentaire Zigbee2MQTT.
Voici les logs
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] socat.sh: executing...
[19:44:16] INFO: Socat not enabled, marking service as down
[cont-init.d] socat.sh: exited 0.
[cont-init.d] zigbee2mqtt.sh: executing...
[19:44:17] INFO: MQTT available, fetching server detail ...
[19:44:18] INFO: Previous config file found, checking backup
[19:44:18] INFO: Creating backup config in '/config/zigbee2mqtt/.configuration.yaml.bk'
[19:44:18] INFO: Adjusting Zigbee2mqtt core yaml config with add-on quirks ...
[cont-init.d] zigbee2mqtt.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[19:44:19] INFO: Handing over control to Zigbee2mqtt Core ...
> zigbee2mqtt@1.23.0 start
> node index.js
et voici ma config
data_path: /config/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: false
mqtt:
base_topic: zigbee2mqtt
server: mqtt://192.168.1.1:1883
user: ************
password: ***********
serial:
port: tcp://192.168.1.173:8888
adapter: ezsp
advanced:
log_level: warn
pan_id: 6754
channel: 25
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blocklist: []
availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
port: 8099
experimental: {}
availability: false
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: '-d -d'
log: false
