Bonjour bonjour,
je m’excuse par avance de la longueur du message ![]()
Je n’arrive pas à configurer Zigbee2Mqtt sur HA_OS de ma Freebox Delta
*J’ai suivi ce tutoriel : zigbee2mqtt-config
l’installation de MQTT avec Mosquitto-MQTT fonctionne bien, démarre sans erreur
l’installation de Zigbee2Mqtt se passe moins bien.
- j’ai du flasher ma sonoff dongle-E pour pouvoir la configurer en mode ember
- un fois flashée, zigbee2Mqtt démarre, mais s’arrête sans message d’erreur. cf log ci dessous :
config mosquitto-mqtt :
logins: []
require_certificate: false
certfile: fullchain.pem
keyfile: privkey.pem
customize:
active: false
folder: mosquitto
log mosquito :
[15:29:23] INFO: Starting NGINX for authentication handling...
[15:29:24] INFO: Starting mosquitto MQTT broker...
2024-12-24 15:29:24: mosquitto version 2.0.18 starting
2024-12-24 15:29:24: Config loaded from /etc/mosquitto/mosquitto.conf.
2024-12-24 15:29:24: Loading plugin: /usr/share/mosquitto/go-auth.so
2024-12-24 15:29:24: Warning: Mosquitto should not be run as root/administrator.
2024-12-24 15:29:24: ├── Username/password checking enabled.
2024-12-24 15:29:24: ├── TLS-PSK checking enabled.
2024-12-24 15:29:24: └── Extended authentication not enabled.
2024-12-24 15:29:24: Opening ipv4 listen socket on port 1883.
2024-12-24 15:29:24: Opening ipv6 listen socket on port 1883.
2024-12-24 15:29:24: Opening websockets listen socket on port 1884.
2024-12-24 15:29:24: mosquitto version 2.0.18 running
2024-12-24 15:29:25: New connection from ::1:46422 on port 1883.
2024-12-24 15:29:25: Client <unknown> disconnected due to protocol error.
[15:29:26] INFO: Successfully send discovery information to Home Assistant.
[15:29:27] INFO: Successfully send service information to the Supervisor.
2024-12-24 15:29:34: New connection from 172.30.32.1:48339 on port 1883.
2024-12-24 15:29:34: Client 3qcD9eoMMaDaC3Ndn3NWB4 disconnected, not authorised.
2024-12-24 15:29:35: New connection from 172.30.32.1:46243 on port 1883.
2024-12-24 15:29:35: New client connected from 172.30.32.1:46243 as 7jLBJDfvwUtcdcNoudLQVU (p2, c1, k60, u'homeassistant').
2024-12-24 15:29:36: Client 7jLBJDfvwUtcdcNoudLQVU disconnected.
2024-12-24 15:29:36: New connection from 172.30.32.1:57437 on port 1883.
2024-12-24 15:29:36: New client connected from 172.30.32.1:57437 as 3PYjwzrjGccjPC1C1Jznkx (p2, c1, k60, u'homeassistant').
2024-12-24 15:29:36: Client 3PYjwzrjGccjPC1C1Jznkx disconnected.
2024-12-24 15:29:36: New connection from 172.30.32.1:59649 on port 1883.
2024-12-24 15:29:36: New client connected from 172.30.32.1:59649 as 5BWFQ8PBrZ9Z4IExfkrcWf (p2, c1, k60, u'homeassistant').
time="2024-12-24T15:29:42+01:00" level=error msg="POST error: Post \"http://127.0.0.1:80/superuser\": EOF"
2024-12-24 15:30:05: New connection from 172.30.32.2:33722 on port 1883.
2024-12-24 15:30:05: Client <unknown> closed its connection.
2024-12-24 15:32:05: New connection from 172.30.32.2:51404 on port 1883.
2024-12-24 15:32:05: Client <unknown> closed its connection.
2024-12-24 15:33:31: New connection from 172.30.32.1:43169 on port 1883.
2024-12-24 15:33:31: New client connected from 172.30.32.1:43169 as 2sdAOsa71GQVoJ7Nl7Bgtk (p2, c1, k60, u'mqtt').
2024-12-24 15:33:36: Client 2sdAOsa71GQVoJ7Nl7Bgtk disconnected.
2024-12-24 15:33:56: New connection from 172.30.32.1:33783 on port 1883.
2024-12-24 15:33:56: New client connected from 172.30.32.1:33783 as 707bBsg7hxO7AFp4sy0ep8 (p2, c1, k60, u'homeassistant').
2024-12-24 15:33:56: Client 707bBsg7hxO7AFp4sy0ep8 disconnected.
config Z2M :
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
user: mqtt
password: mqtt
serial:
port: >-
/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_42a4f4908739ef119eb753f454516304-if00-port0
adapter: ember
log Z2M :
[15:35:28] INFO: Preparing to start...
[15:35:28] INFO: Socat not enabled
[15:35:28] INFO: Starting Zigbee2MQTT...
[15:35:45] INFO: Preparing to start...
[15:35:45] INFO: Socat not enabled
[15:35:46] INFO: Starting Zigbee2MQTT...
[15:36:02] INFO: Preparing to start...
[15:36:02] INFO: Socat not enabled
[15:36:02] INFO: Starting Zigbee2MQTT...
[15:36:19] INFO: Preparing to start...
[15:36:19] INFO: Socat not enabled
[15:36:20] INFO: Starting Zigbee2MQTT...
[15:36:37] INFO: Preparing to start...
[15:36:37] INFO: Socat not enabled
[15:36:37] INFO: Starting Zigbee2MQTT...
[15:37:41] INFO: Preparing to start...
[15:37:42] INFO: Socat not enabled
[15:37:42] INFO: Starting Zigbee2MQTT...
[2024-12-24 15:37:51] info: z2m: Logging to console, file (filename: log.log)
[2024-12-24 15:37:51] info: z2m: Starting Zigbee2MQTT version 1.42.0 (commit #unknown)
[2024-12-24 15:37:51] info: z2m: Starting zigbee-herdsman (2.1.9)
[2024-12-24 15:37:54] info: zh:ember: Using default stack config.
[2024-12-24 15:37:54] info: zh:ember: ======== Ember Adapter Starting ========
[2024-12-24 15:37:54] info: zh:ember:ezsp: ======== EZSP starting ========
[2024-12-24 15:37:54] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-12-24 15:37:54] info: zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2024-12-24 15:37:54] info: zh:ember:uart:ash: Serial port opened
[2024-12-24 15:37:54] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-12-24 15:37:55] info: zh:ember:uart:ash: ======== ASH connected ========
Au final mon service ne tourne pas et j’ai aussi des 502 : bad gateway sur le Z2M
j’ai essayé avec et sans user mqtt, ça n’a pas changé grand chose
[center]## System Information
| version | core-2024.12.5 |
| dev | false |
| hassio | true |
| docker | true |
| user | root |
| virtualenv | false |
| python_version | 3.13.0 |
| os_name | Linux |
| os_version | 6.6.66-haos |
| arch | aarch64 |
| timezone | Europe/Paris |
| config_dir | /config |
| GitHub API | ok |
| GitHub Content | ok |
| GitHub Web | ok |
| HACS Data | ok |
| Installed Version | 2.0.1 |
| Stage | running |
| Available Repositories | 1556 |
| Downloaded Repositories | 4 |
| logged_in | false |
| can_reach_cloud_auth | ok |
| can_reach_cloud | ok |
| host_os | Home Assistant OS 14.1 |
| update_channel | stable |
| supervisor_version | supervisor-2024.12.0 |
| agent_version | 1.6.0 |
| docker_version | 27.2.0 |
| disk_total | 29.8 GB |
| disk_used | 6.0 GB |
| healthy | true |
| supported | true |
| host_connectivity | true |
| supervisor_connectivity | true |
| ntp_synchronized | true |
| virtualization | kvm |
| board | generic-aarch64 |
| supervisor_api | ok |
| version_api | ok |
| installed_addons | Advanced SSH & Web Terminal (19.0.0), File editor (5.8.0), Let’s Encrypt (5.2.10), Mosquitto broker (6.4.1), Zigbee2MQTT (1.42.0-2) |
| dashboards | 3 |
| resources | 0 |
| views | 2 |
| mode | storage |
| oldest_recorder_run | 12 décembre 2024 à 19:50 |
| current_recorder_run | 24 décembre 2024 à 15:22 |
| estimated_db_size | 234.51 MiB |
| database_engine | sqlite |
| database_version | 3.45.3 |
