Dans ce cas, je fais une migration manuelle. Récupération des fichiers yaml, recopie des config. C’est à peine plus loin, mais au moins…
Zigbee via ZHA ? donc core, donc issue de l’installation HAOS qui elle est correcte.
Un exemple d’images par exemple :
root@homeassistant:/hassio# more addons.json |grep image
"image": "homeassistant/{arch}-addon-ssh",
"image": "ghcr.io/hassio-addons/spotify/{arch}",
"image": "ghcr.io/hassio-addons/node-red/{arch}",
"image": "sabeechen/hassio-google-drive-backup-{arch}",
"image": "ghcr.io/hassio-addons/appdaemon/{arch}",
"image": "homeassistant/{arch}-addon-zwave_js",
"image": "ghcr.io/hassio-addons/sqlite-web/{arch}",
"image": "helto4real/hassio-better-presence-{arch}",
"image": "ghcr.io/esphome/esphome-hassio-{arch}",
"image": "zigbee2mqtt/zigbee2mqtt-{arch}",
"image": "ghcr.io/hassio-addons/vscode/{arch}",
"image": "homeassistant/{arch}-addon-mosquitto",
"image": "homeassistant/amd64-addon-ssh",
"image": "ghcr.io/hassio-addons/spotify/amd64",
"image": "ghcr.io/hassio-addons/node-red/amd64",
"image": "sabeechen/hassio-google-drive-backup-amd64",
"image": "ghcr.io/hassio-addons/appdaemon/amd64",
"image": "homeassistant/amd64-addon-zwave_js",
"image": "ghcr.io/hassio-addons/sqlite-web/amd64",
"image": "helto4real/hassio-better-presence-amd64",
"image": "ghcr.io/esphome/esphome-hassio-amd64",
"image": "zigbee2mqtt/zigbee2mqtt-amd64",
"image": "ccab4aaf/amd64-addon-frigate-proxy",
"image": "ghcr.io/hassio-addons/vscode/amd64",
"image": "homeassistant/amd64-addon-mosquitto",
Elles sont toutes typées plus ou moins en dur… Les {arch} marcheront en changeant de plateforme mais pas les amd64
