Bonjour a tous j’aimerai passer ma config Home Assistant de ZHA a Zigbee2Mqtt
mais impossible de faire fonctionner l’add-on Mosquitto broker!
Il a demarré une première fois mais depuis un redémarrage de HA impossible de le relancer.
J’ai essayé plusieurs désinstallations/réinstallation, changement de paramètres diverses et variées rien n’y fait …il charge quelque secondes et rien
Voici les logs et une capture d’écran après une simple installation de l’add-on et une tentative de démarrage.
cont-init: info: running /etc/cont-init.d/mosquitto.sh
[15:46:44] INFO: Setting up user mqtt
[15:46:45] INFO: Certificates found: SSL is available
cont-init: info: /etc/cont-init.d/mosquitto.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
services-up: info: copying legacy longrun mosquitto (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
[15:46:46] INFO: Starting NGINX for authentication handling...
[15:46:46] INFO: Starting mosquitto MQTT broker...
2022-10-18 15:46:46: Warning: Mosquitto should not be run as root/administrator.
[15:46:47] INFO: Successfully send discovery information to Home Assistant.
[15:46:47] INFO: Successfully send service information to the Supervisor.
Merci d’avance de votre aide
Charles
version
core-2022.10.4
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
user
root
virtualenv
false
python_version
3.10.5
os_name
Linux
os_version
5.15.61-v8
arch
aarch64
timezone
Europe/Paris
config_dir
/config
GitHub API
ok
GitHub Content
ok
GitHub Web
ok
GitHub API Calls Remaining
5000
Installed Version
1.28.0
Stage
running
Available Repositories
1122
Downloaded Repositories
14
logged_in
false
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
host_os
Home Assistant OS 9.2
update_channel
stable
supervisor_version
supervisor-2022.10.0
agent_version
1.4.1
docker_version
20.10.17
disk_total
116.5 GB
disk_used
10.2 GB
healthy
true
supported
true
board
rpi4-64
supervisor_api
ok
version_api
ok
installed_addons
Duck DNS (1.15.0), Samba share (10.0.0), Studio Code Server (5.4.0), Terminal & SSH (9.6.1), NGINX Home Assistant SSL proxy (3.1.5), Home Assistant Google Drive Backup (0.108.4), Mosquitto broker (6.1.3)
Salut @AlexHass merci de ta réponse.
Non, a partir du premier « clic démarrer » post installation, plus moyen de modifier quoi que ce soit,le bouton démarrer n’a plus d’effet, je ne peux que désinstaller l’add-on!
Rien de nouveau dans le logs même après rafraichissement.
je vois bien les boutons dans ttes les autres intégrations, mais pas avec mosquitto!
Petite info don je ne connais pas la pertinence: il y a 3 jours lors de ma premiere installation de mosquitto, il s’est lancé correctement mais ce meme jour, un peu plus tard, j’ai fais un restor avec un backup de la nuit précedente a cause d’un problème sur mon integration Tuya. j’ai donc du reinstaller a zero mosquitto et c’est depuis cette résoration que ca ne fonctionne plus!
je relance le sujet, car ayant un peu avancé dans mon problème:
le broker fonctionne bien malgré l’affichage dans HA (Z2MQTT) semble se connecter dessus.
Mon problème maintenant c’est que le souci se répète avec Z2MQTT qui semble au vu les logs se lancer correctement:
[08:46:14] INFO: Preparing to start...
[08:46:15] INFO: Socat not enabled
[08:46:17] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2022-10-24 08:46:22: Logging to console and directory: '/config/zigbee2mqtt/log/2022-10-24.08-46-22' filename: log.txt
Zigbee2MQTT:info 2022-10-24 08:46:22: Starting Zigbee2MQTT version 1.28.0 (commit #unknown)
Zigbee2MQTT:info 2022-10-24 08:46:22: Starting zigbee-herdsman (0.14.62)
Zigbee2MQTT:info 2022-10-24 08:46:23: zigbee-herdsman started (resumed)
Zigbee2MQTT:info 2022-10-24 08:46:23: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20210708,"transportrev":2},"type":"zStack3x0"}'
Zigbee2MQTT:info 2022-10-24 08:46:23: Currently 0 devices are joined:
Zigbee2MQTT:info 2022-10-24 08:46:23: Zigbee: disabling joining new devices.
Zigbee2MQTT:info 2022-10-24 08:46:23: Connecting to MQTT server at mqtt://core-mosquitto:1883
Zigbee2MQTT:info 2022-10-24 08:46:24: Connected to MQTT server
Zigbee2MQTT:info 2022-10-24 08:46:24: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
Zigbee2MQTT:info 2022-10-24 08:46:24: Started frontend on port 0.0.0.0:8099
Bonjour, on dirait le problème quand on restauré une sauvegarde ou les add-ons ce lance plus. Essaye d’éteindre ton RPi, débranché l’alimentation du secteur 10s et rebrancher l’alimentation et redémarrer HA. C’est solution, permet de relancer les add-ons correctement.
