installation trois car mod: numberbox-card, Xiaomi Cloud Map Extractor et Xiaomi Miot Auto
Tous ces add-on pour essayer de nouveau l’intégration du Roborock S7 puisque enfin ils sont compatible avec cette version.
File "/usr/src/supervisor/supervisor/homeassistant/websocket.py", line 134, in async_send_command
return await self._client.async_send_command(message)
File "/usr/src/supervisor/supervisor/homeassistant/websocket.py", line 46, in async_send_command
response = await self.client.receive_json()
File "/usr/local/lib/python3.9/site-packages/aiohttp/client_ws.py", line 291, in receive_json
data = await self.receive_str(timeout=timeout)
File "/usr/local/lib/python3.9/site-packages/aiohttp/client_ws.py", line 276, in receive_str
raise TypeError(f"Received message {msg.type}:{msg.data!r} is not str")
TypeError: Received message 8:1000 is not str
21-07-23 22:11:05 INFO (MainThread) [supervisor.ingress] Update Ingress as panel for a0d7b954_vscode
21-07-23 22:11:05 INFO (MainThread) [supervisor.addons] Add-on 'a0d7b954_vscode' successfully removed
21-07-23 22:11:14 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session None
21-07-23 22:11:15 WARNING (MainThread) [supervisor.api.ingress] Ingress for LQMuGc9EIXZLrURqw_MSbKjX5wXBZpvT0tlQ-uS3soQ not available
21-07-23 22:11:16 WARNING (MainThread) [supervisor.api.ingress] Ingress for LQMuGc9EIXZLrURqw_MSbKjX5wXBZpvT0tlQ-uS3soQ not available
21-07-23 22:11:21 INFO (MainThread) [supervisor.addons] Creating Home Assistant add-on data folder /data/addons/data/a0d7b954_vscode
21-07-23 22:11:21 INFO (SyncWorker_6) [supervisor.docker.interface] Downloading docker image ghcr.io/hassio-addons/vscode/aarch64 with tag 3.6.0.
21-07-23 22:12:34 WARNING (MainThread) [supervisor.api.ingress] Ingress for LQMuGc9EIXZLrURqw_MSbKjX5wXBZpvT0tlQ-uS3soQ not available
21-07-23 22:12:45 INFO (MainThread) [supervisor.addons] Add-on 'a0d7b954_vscode' successfully installed
21-07-23 22:12:47 WARNING (MainThread) [supervisor.api.ingress] Ingress for LQMuGc9EIXZLrURqw_MSbKjX5wXBZpvT0tlQ-uS3soQ not available
21-07-23 22:12:50 INFO (MainThread) [supervisor.ingress] Update Ingress as panel for a0d7b954_vscode
21-07-23 22:12:57 WARNING (MainThread) [supervisor.api.ingress] Ingress for LQMuGc9EIXZLrURqw_MSbKjX5wXBZpvT0tlQ-uS3soQ not available
21-07-23 22:12:57 INFO (SyncWorker_7) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/vscode/aarch64 with version 3.6.0
21-07-23 22:12:59 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session None
journal Core :
2021-07-23 22:14:33 ERROR (MainThread) [homeassistant.components.upnp] Unexpected error fetching Freebox Server data: Error during async_call(), status: 500, body: <?xml version="1.0"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>401</errorCode><errorDescription>Invalid Action</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope>
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 187, in _async_refresh
self.data = await self._async_update_data()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 147, in _async_update_data
return await self.update_method()
File "/usr/src/homeassistant/homeassistant/components/upnp/device.py", line 184, in async_get_traffic_data
values = await asyncio.gather(
File "/usr/local/lib/python3.9/site-packages/async_upnp_client/profiles/igd.py", line 93, in async_get_total_bytes_received
result = await action.async_call()
File "/usr/local/lib/python3.9/site-packages/async_upnp_client/client.py", line 550, in async_call
raise UpnpError(
async_upnp_client.exceptions.UpnpError: Error during async_call(), status: 500, body: <?xml version="1.0"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>401</errorCode><errorDescription>Invalid Action</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope>
2021-07-23 22:15:03 ERROR (MainThread) [homeassistant.components.scrape.sensor] Unable to extract data from HTML for Dicton
2021-07-23 22:15:03 ERROR (MainThread) [homeassistant.components.upnp] Unexpected error fetching Freebox Server data: Error during async_call(), status: 500, body: <?xml version="1.0"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>401</errorCode><errorDescription>Invalid Action</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope>
raise UpnpError(
Je suis sur Firefox, j’ai effacé le cache, j’ai réinstallé mon dernier snapshot et toujours pareil.
Tu as raison, pas de soucis avec chrome
Donc c’est pas dû à HA mais à la mise à jour d’aujourd’hui de Firefox
Solution pour Firefox:
Paramêtres > vie privée et securité > protection renforcée contre le pistage > passage en mode standard (le mode stricte bloque les add-ons)
Ou rester en mode stricte et sur l’url de HA:
Cliquez sur le bouclier situé à gauche de la barre d’adresse.
