Activer / désactiver l’alarme Tyxal+ Deltadore avec Tydom2mqtt
Je souhaiterai pouvoir Activer / désactiver l’alarme Tyxal+ Deltadore avec Tydom2mqtt; j ai réussi a récupérer les infos de mon alarme Tyxal+ mais je n arrive pas a savoir comment activer mon alarme?
[center]## System Information
version core-2026.1.3
container_arch amd64
python_version 3.13.11
os_version 6.12.63-haos
arch x86_64
Installed Version 2.0.5
Available Repositories 2635
Downloaded Repositories 6
logged_in true
subscription_expiration 11 février 2026 à 01:00
relayer_connected true
relayer_region eu-central-1
remote_enabled true
remote_connected true
alexa_enabled true
google_enabled true
remote_server eu-central-1-35.ui.nabu.casa
certificate_status ready
instance_id 79ea40b13f024f9c8262a918163e4eba
host_os Home Assistant OS 17.0
supervisor_version supervisor-2026.01.1
agent_version 1.8.1
docker_version 29.1.3
disk_total 30.8 GB
disk_used 6.9 GB
nameservers 192.168.1.1
virtualization kvm
board ova
installed_addons File editor (5.8.0), Get HACS (1.3.1), tydom2mqtt (3.5.3), Mosquitto broker (6.5.2)
dashboards 3
resources 4
views 19
Network Configuration
adapters lo (disabled), enp0s18 (enabled, default, auto), docker0 (disabled), hassio (disabled), vetheca3e6b (disabled), vethd19bca3 (disabled), vetha40e887 (disabled), vethb17a07e (disabled), veth62fa1db (disabled), veth41c6445 (disabled), veth7d88b92 (disabled)
ipv4_addresses lo (127.0.0.1/8), enp0s18 (192.168.1.194/24), docker0 (172.30.232.1/23), hassio (172.30.32.1/23), vetheca3e6b (), vethd19bca3 (), vetha40e887 (), vethb17a07e (), veth62fa1db (), veth41c6445 (), veth7d88b92 ()
ipv6_addresses lo (::1/128), enp0s18 (fe80::bf39:5b7:8a18:d909/64), docker0 (fe80::48b9:60ff:fe53:8083/64), hassio (fd0c:ac1e:2100::1/48, fe80::9c1d:6ff:fe31:dcdc/64), vetheca3e6b (fe80::e48a:46ff:fe26:f70c/64), vethd19bca3 (fe80::1447:d5ff:fef3:79aa/64), vetha40e887 (fe80::543f:96ff:fe96:f1d3/64), vethb17a07e (fe80::246d:deff:fe9b:a23b/64), veth62fa1db (fe80::8428:2eff:fe74:659d/64), veth41c6445 (fe80::3c41:52ff:fe64:6de4/64), veth7d88b92 (fe80::3083:91ff:fe06:790c/64)
announce_addresses 192.168.1.194, fe80::bf39:5b7:8a18:d909
oldest_recorder_run 16 janvier 2026 à 02:08
current_recorder_run 26 janvier 2026 à 14:01
estimated_db_size 106.32 MiB
database_version 3.49.2
[/center]
