Salut a tous,
Je voudrais savoir si il existe un moyen d’afficher le nom de la zone dans laquelle on se trouve au lieu de présent ou absent ?
Merci d’avance
Résumé
System Health
version: core-2021.4.6
installation_type: Home Assistant Supervised
dev: false
hassio: true
docker: true
virtualenv: false
python_version: 3.8.7
os_name: Linux
os_version: 5.10.17-v8+
arch: aarch64
timezone: Europe/Paris
GitHub API: ok
Github API Calls Remaining: 4999
Installed Version: 1.11.3
Stage: running
Available Repositories: 777
Installed Repositories: 10
logged_in: false
can_reach_cert_server: ok
can_reach_cloud_auth: ok
can_reach_cloud: ok
host_os: Debian GNU/Linux 10 (buster)
update_channel: stable
supervisor_version: supervisor-2021.04.3
docker_version: 20.10.5
disk_total: 109.8 GB
disk_used: 8.9 GB
healthy: true
supported: failed to load: Unsupported
supervisor_api: ok
version_api: ok
installed_addons: File editor (5.3.0), MariaDB (2.3.0), Nginx Proxy Manager (0.11.0), Mosquitto broker (5.1.1), Zigbee2mqtt (1.18.1-1), Terminal & SSH (9.1.1), ESPHome (1.17.1), Visual Studio Code (3.3.1), Node-RED (9.0.1), phpMyAdmin (0.4.0), motionEye (0.12.0)
dashboards: 1
resources: 3
mode: storage
api_endpoint_reachable: ok
