Agrandir largeur d'un bouton
J’utilise cette carte pour mon chauffage :
J’aimerais que le bouton avec l’icone power et la flamme soit plus large (chacun fasse la moitié de la carte par exemple).
Est-ce possible ?
Mon code :
type: custom:stack-in-card
keep:
  margin: false
  box_shadow: false
  background: false
cards:
  - type: grid
    square: false
    columns: 2
    cards:
        style: |
          ha-card {
            padding-bottom: 1px !important;
        primary: CHAMBRE
        secondary: |
          Currently: {{ state_attr('climate.chambre', 'hvac_action') }}
        icon: |-
          {% set mode = states('climate.chambre') %}
          {% if mode == 'off' %}
          mdi:power
          {% elif mode == 'cool' %}
          mdi:snowflake
          {% elif mode == 'heat' %}
          mdi:fire
          {% elif mode == 'heat_cool' %}
          mdi:autorenew
          mdi:home-thermometer
        icon_color: |-
          {% set mode = state_attr('climate.chambre', 'hvac_action') %}
          {% if mode == 'idle' %}
          grey
          {% elif mode == 'cooling' %}
          blue
          {% elif mode == 'heating' %}
          red
          grey
        tap_action: none
      - type: vertical-stack
        cards:
          - type: custom:simple-thermostat
            style: |
              ha-card {
                --st-spacing: px;
              ha-card .current--value {
                color: #ffffff;
              header {
                margin-bottom: 12px !important;
                padding-bottom: 0px !important;
              ha-card .thermostat-trigger {
                color: #9e9e9e;
            entity: climate.chambre
            header:
              icon: false
            decimals: '1'
            fallback: 'Off'
            hide:
              temperature: true
              state: true
            layout:
              mode:
                names: false
                icons: false
                headings: false
              step: row
            step_size: '0.5'
            control:
              hvac:
                'off': false
                heat: false
                cool: false
                heat_cool: false
  - type: custom:mushroom-chips-card
    style: |
      ha-card {
        --chip-box-shadow: none;
        --chip-background: none;
    alignment: justify
    chips:
      - type: template
        entity: sensor.mode_chambre
        icon: mdi:home-thermometer-outline
        content: '{{ states(entity) }}'
      - type: template
        content: '{{state_attr(entity, ''current_temperature'')}} °F'
        tap_action:
          action: more-info
        icon_color: |-
          {% set state=states(entity) %}
          {% if state=='cool' %}
          blue
          {% elif state=='heat' %}
          red
          grey
      - type: template
        double_tap_action:
          action: none
        content: '{{ states(entity) }}% Humidity'
        entity: sensor.temp_chambre_humidity
        icon: mdi:water
        icon_color: blue
        tap_action:
          action: none
        hold_action:
          action: none
  - type: horizontal-stack
    cards:
        primary: null
        secondary: ''
        icon: mdi:power
        entity: input_boolean.chauffage_chambre
        layout: horizontal
        tap_action:
          action: call-service
          service: input_boolean.turn_off
          service_data:
            entity_id: input_boolean.chauffage_chambre
        primary: null
        secondary: ''
        icon: mdi:fire
        layout: horizontal
        tap_action:
          service: input_boolean.turn_on
          service_data:
        icon_color: |-
          grey
          blue
          red
          grey
Je ne suis pas sur mais il me semble que les mushrooms-cards ne permettent pas autre chose qu’un ratio 1/1. Tu pourrais le faire sans souci avec des button-cards en revanche.
Je pourrais avoir le même aspect de boutons ? Tu aurais un aperçu par exemple ?
Bj
Si tu veux tu as ceci en minimaliste
Aussi en version mushroom
et :
Merci pour ta réponse, ma carte viens justement du dernier lien que j’ai épuré à ma manière.
Me reste juste ces 2 boutons qui me sont utiles et que j’aimerais « plus grand »
Je continue mes recherche
Je te fais un exemple avec button-card et je te poste ça dans la soirée…
Voilà ce que ça donne chez moi :
keep:
  margin: false
  box_shadow: false
  background: false
cards:
  - type: grid
    square: false
    columns: 2
    cards:
        mod_card:
          style: |
            ha-card {
        primary: CHAMBRE
        secondary: |
        icon: |-
          mdi:power
          mdi:snowflake
          mdi:fire
          mdi:autorenew
        icon_color: |-
          grey
          blue
          red
          grey
        tap_action: none
        cards:
            style: |
              ha-card {
                --st-spacing: px;
                color: #ffffff;
              header {
                color: #9e9e9e;
            header:
              icon: false
            decimals: '1'
            fallback: 'Off'
            hide:
              temperature: true
              state: true
            layout:
              mode:
                names: false
                icons: false
                headings: false
              step: row
            step_size: '0.5'
            control:
              hvac:
                'off': false
                heat: false
                cool: false
                heat_cool: false
    style: |
      ha-card {
    alignment: justify
    chips:
      - type: template
      - type: template
        tap_action:
          action: more-info
        icon_color: |-
          blue
          red
          grey
      - type: template
        double_tap_action:
          action: none
        icon: mdi:water
        icon_color: blue
        tap_action:
          action: none
        hold_action:
          action: none
    cards:
      - type: custom:button-card
        aspect_ratio: 3/1
        custom_fields:
          power_button:
            card:
              aspect_ratio: 3/0.9
              icon: mdi:power
              icon_size: 80%
              styles:
                card:
                  - background-color: rgb(44,44,44)
                icon:
                  - color: rgb(158,158,158)
                  - width: 40px
        tap_action:
          service_data:
        styles:
          custom_fields:
            power_button:
              - position: absolute
              - top: 5px
              - left: 5px
              - width: 236px
        aspect_ratio: 3/1
        custom_fields:
          fire_button:
            card:
              aspect_ratio: 3/0.9
              icon: mdi:fire
              icon_size: 80%
              styles:
                card:
                icon:
                  - color: >-
                      grey
                      blue
                      red
                      grey
                  - width: 40px
        tap_action:
          service_data:
        styles:
          custom_fields:
            fire_button:
              - top: 5px
              - left: 5px
              - width: 236px
Tu peux jouer sur la position exacte de chacun des deux boutons aisni que leurs tailles
Il est probable que la couleur de l’icone de ton deuxième bouton ne fonctionne pas car la manière de procéder est un peu différente avec button-card.
Je te mets un exemple de changement de couleur de l’icône en fonction d’un changement d’état pour un button-card.
Ca sera à adapter à ton entité.
Voici le code pour le changement de couleur du nom d’un custom_fields en fonction de l’état de plusieurs capteurs (c’est à adapter : changer « name: » par « icon: » dans le « styles: » du custom_fields « fire_button: ») :
      styles:
        name:
          - font-size: |
                if (states['binary_sensor.maison_detecteur_de_fermeture_portail_contact'].state == 'off' && states['binary_sensor.maison_detecteur_d_ouverture_battant_droit_portail_contact'].state == 'on')
                  return '1.0em';
                else if (states['binary_sensor.maison_detecteur_de_fermeture_portail_contact'].state == 'on' && states['binary_sensor.maison_detecteur_d_ouverture_battant_droit_portail_contact'].state == 'off')
                  return '1.0em';
                else if (states['binary_sensor.maison_detecteur_de_fermeture_portail_contact'].state == 'on' && states['binary_sensor.maison_detecteur_d_ouverture_battant_droit_portail_contact'].state == 'on')
                  return '0.9em';
          - font-weight: bold
          - align-self: end
          - color: |
                  return 'rgba(0,128,0,0.7)';
                  return 'rgba(255,0,0,0.7)';
                  return 'rgba(255,140,0,0.7)';
Je t’ai posté un exemple, tu dois pouvoir créer une nouvelle carte vierge et coller directement l’ensemble du code dedans.
Dis-moi ce que ça donne chez toi.
Merci pour ton exemple, j’ai ce problème en voulant réduire :
keep:
  margin: false
  box_shadow: false
  background: false
cards:
  - type: grid
    square: false
    columns: 2
    cards:
        mod_card:
          style: |
            ha-card {
        primary: CHAMBRE
        secondary: |
        icon: |-
          mdi:power
          mdi:snowflake
          mdi:fire
          mdi:autorenew
        icon_color: |-
          grey
          blue
          red
          grey
        tap_action: none
        cards:
            style: |
              ha-card {
                --st-spacing: px;
                color: #ffffff;
              header {
                color: #9e9e9e;
            header:
              icon: false
            decimals: '1'
            fallback: 'Off'
            hide:
              temperature: true
              state: true
            layout:
              mode:
                names: false
                icons: false
                headings: false
              step: row
            step_size: '0.5'
            control:
              hvac:
                'off': false
                heat: false
                cool: false
                heat_cool: false
    style: |
      ha-card {
    alignment: justify
    chips:
      - type: template
      - type: template
        tap_action:
          action: more-info
        icon_color: |-
          blue
          red
          grey
      - type: template
        double_tap_action:
          action: none
        icon: mdi:water
        icon_color: blue
        tap_action:
          action: none
        hold_action:
          action: none
    cards:
        aspect_ratio: 3/1
        custom_fields:
          power_button:
            card:
              aspect_ratio: 5/1
              icon: mdi:power
              icon_size: 80%
              styles:
                card:
                icon:
                  - width: 40px
        tap_action:
          service_data:
        styles:
          custom_fields:
            power_button:
              - top: 0px
              - left: 5px
              - width: 200px
        aspect_ratio: 1/1
        custom_fields:
          fire_button:
            card:
              aspect_ratio: 5/1
              icon: mdi:fire
              icon_size: 80%
              styles:
                card:
                icon:
                  - color: >-
                      grey
                      blue
                      red
                      grey
                  - width: 40px
        tap_action:
          service_data:
        styles:
          custom_fields:
            fire_button:
              - top: 0px
              - left: 3px
              - width: 200px
bon on vas bipper @WarC0zes , il aime bien les cards :grin: :wink:
Le problème, c’est l’apparition de la croix et de « CHAUFFAGE CHAMBRE » ?
Oui, comment les virer ou cacher ?
Il manque une valeur a --st-spacing:
Ajoutes « show_name: false » juste sous « - type: custom: button-card »
        show_name: false
        show_icon: false
        show_state: false
        aspect_ratio: 3/1
Non Non! tu confonds avec @anon41081891 et ces custom_fields :rofl:
Ok avec les show à false c’est good mais la taille de la carte a une valeur définis, comment éviter tout le vide en bas :
@WarC0zes
euh , tu as su gere des card assez ouf par le passé !! meme encore aujourd’hui
comme celle pour les NAS et la netatmo …
Essaye en modifiant « aspect_ratio: 3/1 » en augmentant le premier chiffre
Si ça ne donne rien, reposte le code complet de la carte avec les modifications
J’ai essayé plusieurs truc mais je peut pas faire plus petit car les boutons ont une partie invisible (visible sur cette photo) qui prend la place :
Le code :
keep:
  margin: false
  box_shadow: false
  background: false
cards:
  - type: grid
    square: false
    columns: 2
    cards:
        mod_card:
          style: |
            ha-card {
        primary: CHAMBRE
        secondary: |
        icon: |-
          mdi:power
          mdi:snowflake
          mdi:fire
          mdi:autorenew
        icon_color: |-
          grey
          blue
          red
          grey
        tap_action: none
        cards:
            style: |
              ha-card {
                --st-spacing: px;
                color: #ffffff;
              header {
                color: #9e9e9e;
            header:
              icon: false
            decimals: '1'
            fallback: 'Off'
            hide:
              temperature: true
              state: true
            layout:
              mode:
                names: false
                icons: false
                headings: false
              step: row
            step_size: '0.5'
            control:
              hvac:
                'off': false
                heat: false
                cool: false
                heat_cool: false
    style: |
      ha-card {
    alignment: justify
    chips:
      - type: template
      - type: template
        tap_action:
          action: more-info
        icon_color: |-
          blue
          red
          grey
      - type: template
        double_tap_action:
          action: none
        icon: mdi:water
        icon_color: blue
        tap_action:
          action: none
        hold_action:
          action: none
    cards:
        show_name: false
        show_icon: false
        show_state: false
        aspect_ratio: 2/1
        custom_fields:
          power_button:
            card:
              aspect_ratio: 5/1
              icon: mdi:power
              icon_size: 80%
              styles:
                card:
                icon:
                  - width: 40px
        tap_action:
          service_data:
        styles:
          custom_fields:
            power_button:
              - top: 0px
              - left: 5px
              - width: 200px
        aspect_ratio: 2/1
        show_name: false
        show_icon: false
        show_state: false
        custom_fields:
          fire_button:
            card:
              aspect_ratio: 5/1
              icon: mdi:fire
              icon_size: 10%
              styles:
                card:
                icon:
                  - color: >-
                      grey
                      blue
                      red
                      grey
                  - width: 40px
        tap_action:
          service_data:
        styles:
          custom_fields:
            fire_button:
              - top: 0px
              - left: 3px
              - width: 200px
La fonction du bouton doit avoir la même taille que l’icone du bouton
Je dois partir là, mais je regarde ça en soirée. Dans le pire des cas, je te refais une carte complète basée uniquement sur une button-card avec des custom_fields pour chacune des parties que tu as actuellement. Il faudra juste changer les entités que je mettrais par les tiennes car là je travaille en aveugle avec des entités qui ne fonctionnent pas chez moi.
Oui pas de soucis merci
