Bonjour à tous
j’ai créé un flow mais il ne fonctionne pas.
Voici le code
[{"id":"6d0399942d9db06d","type":"tab","label":"Flux 5","disabled":false,"info":"","env":[]},{"id":"b9b24f6d659d423b","type":"server-state-changed","z":"6d0399942d9db06d","name":"David Présent","server":"ba42ae4e.55da8","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"device_tracker.david_weber","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"home","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"seconds","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":410,"y":120,"wires":[["b9ecdee94b06beea"],[]]},{"id":"82abcbb81c5c1f90","type":"comment","z":"6d0399942d9db06d","name":"CAMERA EZVIZ","info":"","x":240,"y":80,"wires":[]},{"id":"b9ecdee94b06beea","type":"api-call-service","z":"6d0399942d9db06d","name":"Caméra OFF","server":"ba42ae4e.55da8","version":5,"debugenabled":false,"domain":"alarm_control_panel","service":"alarm_disarm","areaId":[],"deviceId":[],"entityId":["alarm_control_panel.ezviz_alarm"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":650,"y":180,"wires":[["bf830b2a04cff140"]]},{"id":"bf830b2a04cff140","type":"api-call-service","z":"6d0399942d9db06d","name":"Message","server":"ba42ae4e.55da8","version":5,"debugenabled":false,"domain":"telegram_bot","service":"send_message","areaId":[],"deviceId":[],"entityId":[],"data":"{\"message\":\"Ezviz désactivé\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":820,"y":180,"wires":[[]]},{"id":"f1d50c464b2ecd0f","type":"server-state-changed","z":"6d0399942d9db06d","name":"David Absent","server":"ba42ae4e.55da8","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"device_tracker.david_weber","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"not_home","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"seconds","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":270,"y":240,"wires":[["b6962dd878e71d89"],[]]},{"id":"5f253877aae229f4","type":"api-call-service","z":"6d0399942d9db06d","name":"Caméra ON","server":"ba42ae4e.55da8","version":5,"debugenabled":false,"domain":"alarm_control_panel","service":"alarm_arm_away","areaId":[],"deviceId":[],"entityId":["alarm_control_panel.ezviz_alarm"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":650,"y":240,"wires":[["980f6ffd3756535c"]]},{"id":"980f6ffd3756535c","type":"api-call-service","z":"6d0399942d9db06d","name":"Message","server":"ba42ae4e.55da8","version":5,"debugenabled":false,"domain":"telegram_bot","service":"send_message","areaId":[],"deviceId":[],"entityId":[],"data":"{\"message\":\"Ezviz activé\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":820,"y":240,"wires":[[]]},{"id":"b6962dd878e71d89","type":"api-current-state","z":"6d0399942d9db06d","name":"Corinne absente ","server":"61614394.82253c","version":3,"outputs":2,"halt_if":"not_home","halt_if_type":"str","halt_if_compare":"is","entity_id":"device_tracker.corinne_weber","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":440,"y":240,"wires":[["5f253877aae229f4"],[]]},{"id":"eea7922a24f395ff","type":"server-state-changed","z":"6d0399942d9db06d","name":"Corinne présente ","server":"ba42ae4e.55da8","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"device_tracker.corinne_weber","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"home","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":420,"y":180,"wires":[["b9ecdee94b06beea"],[]]},{"id":"ba42ae4e.55da8","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true},{"id":"61614394.82253c","type":"server","name":"Home Assistant","addon":true}]
voici l’image
alors que le wifi de Corinne était actif comme le mien, mais sur le flow l’on voit que depuis le 03 novembre rien !!!
AUTRE QUESTION
Lorsque David ou Corinne active le wifi, je reçois 2 fois la notification, ce qui est logique, comment faire pour ne la recevoir qu’une seule fois.
Merci d’avance
