J'utilise un système de "logs" pour avoir un visuel de mes flow nodered sur home assistant.
J'aimerai ajouter dans le logs, la date et l'heure du style Le 20/04 à 22:40 avant un message (ici présence détecté).
Je débute dans nodered et home assistant ![]()
{"value":"Présence détécté"}
[{"id":"d5d659757f8afe8c","type":"inject","z":"b31d9bde553710c5","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":400,"y":140,"wires":[["68a6d2d9be056d1f"]]},{"id":"68a6d2d9be056d1f","type":"api-call-service","z":"b31d9bde553710c5","name":"Logs arrosage","server":"2ac13f9d67a76d68","version":5,"debugenabled":false,"domain":"input_text","service":"set_value","areaId":[],"deviceId":[],"entityId":["input_text.logs_arrosage"],"data":"{\"value\":\"Présence détécté\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":600,"y":140,"wires":[[]]},{"id":"2ac13f9d67a76d68","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30"}]
En vous remerciant par avance.
System Health
| version | core-2022.4.5 |
| installation_type | Home Assistant Supervised |
| dev | false |
| hassio | true |
| docker | true |
| user | root |
| virtualenv | false |
| python_version | 3.9.9 |
| os_name | Linux |
| os_version | 5.10.0-13-amd64 |
| arch | x86_64 |
| timezone | Europe/Paris |
| logged_in | false |
| can_reach_cloud_auth | ok |
| can_reach_cloud | ok |
| host_os | Debian GNU/Linux 11 (bullseye) |
| update_channel | stable |
| supervisor_version | supervisor-2022.04.0 |
| docker_version | 20.10.14 |
| disk_total | 27.3 GB |
| disk_used | 6.6 GB |
| healthy | true |
| supported | true |
| supervisor_api | ok |
| version_api | ok |
| installed_addons | Z-Wave JS (0.1.56), Node-RED (11.1.1), File editor (5.3.3), Samba share (9.5.1), Home Assistant Google Drive Backup (0.106.2) |
| dashboards | 3 |
| resources | 0 |
| views | 9 |
| mode | storage |
