bonjour,
pour utiliser filesize j’ai voulu ajouter allowlist_external_dirs dans mon fichier configuration.yaml.
Quand je fais vérifier la configuration j’ai l’erreur suivante
Integration error: allowlist_external_dirs - Integration ‹ allowlist_external_dirs › not found.
Dans les logs apparaît :
Logger: homeassistant.setup
Source: setup.py:221
First occurred: 17:31:49 (1 occurrences)
Last logged: 17:31:49Setup failed for ‹ allowlist_external_dirs ›: Integration not found.
Voici mon fichier
default_config:
allowlist_external_dirs:
- /config/
frontend:
extra_module_url:
- /local/card-mod.js
script: !include scripts.yaml
scene: !include scenes.yaml
python_script:
logger:
default: info
command_line: !include command_line.yaml
#template:
# - sensor: !include template_sensors.yaml
[center]## System Information
| version | core-2023.12.3 |
| dev | false |
| hassio | true |
| docker | true |
| user | root |
| virtualenv | false |
| python_version | 3.11.6 |
| os_name | Linux |
| os_version | 6.1.63-haos |
| arch | aarch64 |
| timezone | Europe/Paris |
| config_dir | /config |
| GitHub API | ok |
| GitHub Content | ok |
| GitHub Web | ok |
| Installed Version | 1.33.0 |
| Stage | running |
| Available Repositories | 1374 |
| Downloaded Repositories | 14 |
| HACS Data | ok |
| logged_in | false |
| can_reach_cloud_auth | ok |
| can_reach_cloud | ok |
| host_os | Home Assistant OS 11.2 |
| update_channel | stable |
| supervisor_version | supervisor-2023.12.0 |
| agent_version | 1.6.0 |
| docker_version | 24.0.7 |
| disk_total | 28.0 GB |
| disk_used | 4.9 GB |
| healthy | true |
| supported | true |
| board | green |
| supervisor_api | ok |
| version_api | ok |
| installed_addons | File editor (5.7.0), Samba share (12.2.0), Terminal & SSH (9.8.1), SQLite Web (4.0.0) |
| dashboards | 4 |
| resources | 13 |
| views | 12 |
| mode | storage |
| oldest_recorder_run | 16 décembre 2023 à 13:31 |
| current_recorder_run | 26 décembre 2023 à 17:31 |
| estimated_db_size | 111.38 MiB |
| database_engine | sqlite |
| database_version | 3.41.2 |
Xiaomi Gateway 3
| version | 3.3.4 (f6c434b) |
