Du jour au lendemain cette config de button-card n’a plus fonctionné. Je n’ai pas trouvé la raison.
Il s’agit d’animer l’icone et de la colorier en rouge lorsque le bouton est enfoncé.
L’icone est remise remise en bleu fixe par un autre bouton.
Actuellement, l’icone reste noire fixe !
Pouvez-vous m’aider à dissiper ce mystère?
type: custom:button-card
tap_action:
action: call-service
service: input_boolean.turn_on
service_data:
entity_id: input_boolean.test
show_state: true
icon: mdi:download-multiple
card_mod:
style: |
@keyframes blink {
0% {opacity: 0}
49% {opacity: 0}
50% {opacity: 1}
ha-icon {
{% set var_action = ‹ input_boolean.test › %}
{% if is_state(var_action,‹ on ›) %}
animation: blink 1s linear infinite;
color: red !important
{% elif is_state(var_action,‹ off ›) %}
color: #44739e !important
version |
core-2023.8.1 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.11.4 |
os_name |
Linux |
os_version |
6.1.39 |
arch |
x86_64 |
timezone |
Europe/Paris |
config_dir |
/config |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
GitHub API Calls Remaining |
5000 |
Installed Version |
1.32.1 |
Stage |
running |
Available Repositories |
1268 |
Downloaded Repositories |
35 |
logged_in |
false |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 10.4 |
update_channel |
stable |
supervisor_version |
supervisor-2023.07.1 |
agent_version |
1.5.1 |
docker_version |
23.0.6 |
disk_total |
234.0 GB |
disk_used |
37.7 GB |
healthy |
true |
supported |
true |
board |
generic-x86-64 |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
Studio Code Server (5.10.0), Home Assistant Google Drive Backup (0.111.1), AppDaemon (0.13.3), Node-RED (14.4.3), Samba share (10.0.2), Duck DNS (1.15.0), File editor (5.6.0), ESPHome (2023.7.1), Zigbee2MQTT (1.32.2-1), NGINX Home Assistant SSL proxy (3.5.0), SQLite Web (3.9.0), Mosquitto broker (6.2.1), Grafana (9.0.3), InfluxDB (4.7.0), Music Assistant BETA (2.0.0b63), RTSPtoWeb - WebRTC (1.4.0), MariaDB (2.6.1), Advanced SSH & Web Terminal (15.0.6) |
dashboards |
4 |
resources |
20 |
views |
33 |
mode |
storage |
oldest_recorder_run |
31 juillet 2023 à 06:02 |
current_recorder_run |
6 août 2023 à 11:28 |
estimated_db_size |
535.08 MiB |
database_engine |
sqlite |
database_version |
3.41.2 |
Sonoff
version |
3.5.2 (2ad1cd7) |
cloud_online |
0 / 1 |
local_online |
1 / 1 |
tu as une autre façon pour les animations directement avec button-card.
entity: input_boolean.test
state:
- value: 'on'
color: red
styles:
icon:
- animation: blink 2s linear infinite
- value: 'off'
color: '#44739e'
tap_action:
hold_action:
service: input_boolean.turn_off
show_state: true
Il y a eu une modification dans les dernières maj de button-card pour service_data:
qui deviens data:
quand tu utilise un service.
avant
tap_action:
service_data:
après
tap_action:
Ensuite ton soucis viens d’un changement dans button-card ou ha-icon
est remplacer par ha-state-icon
. Ta cas changer ca dans card_mod, pour corriger ton erreur.
- icons: replace ha-icon with ha-state-icon to follow new HA’s icons per domain automatically (ab6a3f5)
Merci pour vos explications et solutions. Le sujet est clos!
