J’ai de nouveau essayé en suivant ce qu’ils indiquent sous Ubuntu mais cela ne fonctionne pas dans mon cas.
J’ai également essayé de changer le canal de la clé pour le mettre sur le 15 (actuellement 11) et ça plante avec le code erreur suivant :
TypeError
can’t convert null to object
r@http://homeassistant.local:8123/api/hassio_ingress/JNZHn-qaL-jWL0D2im7mcU7w4nYh1nBTraxPRGXJzko/assets/index-4e00f6e9.js:53:9630 r@http://homeassistant.local:8123/api/hassio_ingress/JNZHn-qaL-jWL0D2im7mcU7w4nYh1nBTraxPRGXJzko/assets/index-4e00f6e9.js:53:9692 lUe@http://homeassistant.local:8123/api/hassio_ingress/JNZHn-qaL-jWL0D2im7mcU7w4nYh1nBTraxPRGXJzko/assets/index-4e00f6e9.js:53:9732 Se/this.onSettingsSave@http://homeassistant.local:8123/api/hassio_ingress/JNZHn-qaL-jWL0D2im7mcU7w4nYh1nBTraxPRGXJzko/assets/index-b5a4d188.js:1:8584 e/a.onSubmit/<@http://homeassistant.local:8123/api/hassio_ingress/JNZHn-qaL-jWL0D2im7mcU7w4nYh1nBTraxPRGXJzko/assets/bootstrap-5.esm-b480a4c5.js:11:47737 lD@http://homeassistant.local:8123/api/hassio_ingress/JNZHn-qaL-jWL0D2im7mcU7w4nYh1nBTraxPRGXJzko/assets/index-4e00f6e9.js:41:9885 SD@http://homeassistant.local:8123/api/hassio_ingress/JNZHn-qaL-jWL0D2im7mcU7w4nYh1nBTraxPRGXJzko/assets/index-4e00f6e9.js:43:31876 K5@http://homeassistant.local:8123/api/hassio_ingress/JNZHn-qaL-jWL0D2im7mcU7w4nYh1nBTraxPRGXJzko/assets/index-4e00f6e9.js:43:31458 K5@http://homeassistant.local:8123/api/hassio_ingress/JNZHn-qaL-jWL0D2im7mcU7w4nYh1nBTraxPRGXJzko/assets/index-4e00f6e9.js:43:31368 Pze@http://homeassistant.local:8123/api/hassio_ingress/JNZHn-qaL-jWL0D2im7mcU7w4nYh1nBTraxPRGXJzko/assets/index-4e00f6e9.js:43:31017 Fze@http://homeassistant.local:8123/api/hassio_ingress/JNZHn-qaL-jWL0D2im7mcU7w4nYh1nBTraxPRGXJzko/assets/index-4e00f6e9.js:43:40891 oi@http://homeassistant.local:8123/api/hassio_ingress/JNZHn-qaL-jWL0D2im7mcU7w4nYh1nBTraxPRGXJzko/assets/index-4e00f6e9.js:43:40246 CD@http://homeassistant.local:8123/api/hassio_ingress/JNZHn-qaL-jWL0D2im7mcU7w4nYh1nBTraxPRGXJzko/assets/index-4e00f6e9.js:43:36851 Gn@http://homeassistant.local:8123/api/hassio_ingress/JNZHn-qaL-jWL0D2im7mcU7w4nYh1nBTraxPRGXJzko/assets/index-4e00f6e9.js:41:3283 Wt/<@http://homeassistant.local:8123/api/hassio_ingress/JNZHn-qaL-jWL0D2im7mcU7w4nYh1nBTraxPRGXJzko/assets/index-4e00f6e9.js:43:34230
Je suis dépité. J’ai l’impression que j’aurais du rester sous ZHA, au moins ça fonctionnait simplement alors que là rien ne fonctionne. Je ne comprends pas.
