Appareil dans Z2M
Bonsoir,
je viens de faire une nouvelle installation de HAOS où j’ai installé z2m. J’ai inclus un appareil qui semble fonctionner mais je ne vois aucune entité le concernant.
infos   2024-10-26 18:50:55 z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Cube aqara', payload '{"action":"flip90","action_angle":null,"action_from_side":3,"action_side":5,"action_to_side":5,"angle":35.37,"battery":null,"device_temperature":null,"from_side":3,"linkquality":111,"power_outage_count":null,"side":5,"to_side":5,"voltage":null}'
infos   2024-10-26 18:50:55 z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Cube aqara', payload '{"action":"","action_angle":null,"action_from_side":null,"action_side":null,"action_to_side":null,"angle":35.37,"battery":null,"device_temperature":null,"linkquality":111,"power_outage_count":null,"side":5,"voltage":null}'
infos   2024-10-26 18:50:55 z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Cube aqara/action', payload 'flip90'
erreur   2024-10-26 18:51:41 zh:zigate:driver: Parsing error: Error: Message '8008' not found
informations   2024-10-26 18:52:43 z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Cube aqara', payload '{"action":"wakeup","action_angle":null,"action_from_side":null,"action_side":null,"action_to_side":null,"angle":35.37,"battery":null,"device_temperature":null,"linkquality":111,"power_outage_count":null,"side":5,"voltage":null}'
informations   2024-10-26 18:52:43 z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Cube aqara', payload '{"action":"","action_angle":null,"action_from_side":null,"action_side":null,"action_to_side":null,"angle":35.37,"battery":null,"device_temperature":null,"linkquality":111,"power_outage_count":null,"side":5,"voltage":null}'
informations   2024-10-26 18:52:43 z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Cube aqara/action', payload 'wakeup'
informations   2024-10-26 18:52:44 z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Cube aqara', payload '{"action":"flip90","action_angle":null,"action_from_side":5,"action_side":0,"action_to_side":0,"angle":35.37,"battery":null,"device_temperature":null,"from_side":5,"linkquality":138,"power_outage_count":null,"side":0,"to_side":0,"voltage":null}'
informations   2024-10-26 18:52:44 z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Cube aqara', payload '{"action":"","action_angle":null,"action_from_side":null,"action_side":null,"action_to_side":null,"angle":35.37,"battery":null,"device_temperature":null,"linkquality":138,"power_outage_count":null,"side":0,"voltage":null}'
informations   2024-10-26 18:52:44 z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Cube aqara/action', payload 'flip90'
error 2024-10-26 18:53:41zh:zigate:driver: Parsing error: Error: Message '8008' not found
[center]
version core-2024.10.3
python_version 3.12.4
os_version 6.6.31-haos-raspi
Installed Version 2.0.1
Available Repositories 1520
Downloaded Repositories 1
supervisor_version supervisor-2024.10.3
agent_version 1.6.0
docker_version 27.2.0
disk_total 234.0 GB
disk_used 6.3 GB
virtualization
board rpi5-64
installed_addons Advanced SSH & Web Terminal (19.0.0), Samba share (12.3.2), Get HACS (1.3.1), File editor (5.8.0), Studio Code Server (5.17.2), Mosquitto broker (6.4.1), Zigbee2MQTT (1.40.2-1)
dashboards 2
resources 0
views 1
oldest_recorder_run 22 octobre 2024 à 08:20
current_recorder_run 26 octobre 2024 à 18:24
estimated_db_size 2.15 MiB
database_version 3.45.3
[/center] `Quelles peuvent en être les raisons ? Merci de votre aide ___
Tu l’as cherché dans l’intégration mqtt
Dans Z2M, tu vois bien l’appareil en question ?
Quand tu renomme l’appareil, tu active; renommer sous HA aussi?
Tu le cherche bien dans MQTT côté HA ?
@ddfdom
Oui je le vois dans mqtt
@AlexHass
Oui également
non, c’est dans paramètres / appareils et services.
@WarC0zes Merci pour cette suggestion. Il n’apparaissait pas. Je l’ai supprimé puis re-inclus. Tout semble normal maintenant. Merci à vous 3 et bonne soirée .
