Arrêt de z2m. Impossible de le redémarrer
Bonjour, depuis hier matin, zigbee2mqtt s’est arrêté brutalement et depuis je n’arrive plus à le redémarrer même après avoir désinstallé et réinstallé le broker Mosquitto et z2m
version core-2023.6.2
python_version 3.11.4
os_version 6.1.21-v8+
Installed Version 1.32.1
Available Repositories 1347
Downloaded Repositories 23
host_os Debian GNU/Linux 11 (bullseye)
supervisor_version supervisor-2023.06.2
agent_version 1.4.1
docker_version 23.0.3
disk_total 458.2 GB
disk_used 13.1 GB
supported failed to load: Unsupported
installed_addons Terminal & SSH (9.7.1), Samba share (10.0.2), File editor (5.6.0), Duck DNS (1.15.0), NGINX Home Assistant SSL proxy (3.5.0), Mosquitto broker (6.2.1), Zigbee2MQTT (1.31.2-1)
dashboards 6
resources 19
views 6
oldest_recorder_run 10 juin 2023 à 10:32
current_recorder_run 20 juin 2023 à 05:46
estimated_db_size 106.64 MiB
database_version 3.41.2
Le journal de z2m indique ceci:
[06:07:28] INFO: Preparing to start…
[06:07:28] INFO: Socat not enabled
[06:07:30] INFO: Starting Zigbee2MQTT…
/app/data/extension/externally-loaded.js:1
import * as exposes from ‹ ../lib/exposes ›;
SyntaxError: Cannot use import statement outside a module
at new Script (node:vm:100:7)
at createScript (node:vm:265:10)
at Object.runInNewContext (node:vm:306:10)
at loadModuleFromText (/app/lib/util/utils.ts:150:8)
at loadModuleFromFile (/app/lib/util/utils.ts:157:12)
at Object.getExternalConvertersDefinitions (/app/lib/util/utils.ts:167:25)
at getExternalConvertersDefinitions.next ()
at new ExternalConverters (/app/lib/extension/externalConverters.ts:12:20)
at new Controller (/app/lib/controller.ts:84:58)
at start (/app/index.js:106:18)
voici mon fichier de configuration de z2m :
data_path: /config/zigbee2mqtt
socat:
  enabled: false
  master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
  slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
  options: "-d -d"
  log: false
mqtt:
  base_topic: zigbee2mqtt
  server: mqtt://192.168.1.**:1883
  user: mqtt_admin
  password: *********
serial:
  port: /dev/ttyACM0
  adapter: ezsp
Je ne sais plus quoi faire, j’ai 70 appareils sous z2m en temps normal dont l’ensemble de l’éclairage de mon domicile et j’ai commencé à taper ce message dans le noir…
Hello.
Tu n’as pas bricolé un nouvel appareil avec un converter ?
Par principe il faut s’assurer que la domotique ça ajoute des fonctions, pas que le fonctionnement en soit dépendant
Bonjour Pulpy,
J’ai effectivement ajouté une ligne vers un converter. Il est donc possible que mon problème vienne de là ?
Je sais que la domotique et moi, ce n’est pas une grande histoire d’amour mais je suis borné :slight_smile:
Vire la ça ira mieux
ça venait bien du converter… Je viendrais demander sur le forum à la prochaine galère, ça m’évitera de devoir tout réinstaller à 4 heure du mat.
Merci pulpy
Bonsoir Pulpy
Je commence peu a peu à m’équiper en zigbee.
Afin de m’éviter de futur souci… :grin: peut tu me dire c’est quoi un converter ?
Un bout de fichier de config qui permet de faire fonctionner un appareil que z2m ne connait pas encore.
Tant que tu peux éviter c’est mieux :wink:
