### What happened?
Today new a firmware upgrade for IKEA bulbs was offered, so …I started to upgrade the corresponding bulbs.
Sometime later I noticed my LED2201G8 in the basement do flash every few seconds. They are offline, factory reset does not work.
After looking for the cause, I noticed the new 3.0.21 is not for the LED2201G8, but only for my other LED2107C4, which do work fine after the upgrade.
Since the firmware versions of both bulbs types where the same before, I think, there has to be some sort of error by IKEA? Or is it z2m?
### What did you expect to happen?
_No response_
### How to reproduce it (minimal and precise)
n/a
### Zigbee2MQTT version
1.38.0 commit: fe048e6
### Adapter firmware version
20221226
### Adapter
Sonoff USB P
### Setup
docker in lxc container
### Debug log
Logs for LED2201G8:
[2024-07-11 13:33:44] info: z2m: Update available for 'Keller Lampe 2'
[2024-07-11 13:33:44] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Keller Lampe 2', payload '{"brightness":254,"color_mode":"xy","color_options":{"execute_if_off":true},"last_seen":"2024-07-11T13:33:44+02:00","linkquality":200,"power_on_behavior":"on","state":"OFF","update":{"installed_version":50331664,"latest_version":50331681,"state":"available"},"update_available":null}'
[2024-07-11 13:33:44] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/response/device/ota_update/check', payload '{"data":{"id":"Keller Lampe 2","updateAvailable":true},"status":"ok","transaction":"izs9s-2"}'
[2024-07-11 13:33:44] info: z2m: Update available for 'Keller Lampe 1'
[2024-07-11 13:33:44] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Keller Lampe 1', payload '{"brightness":254,"color_mode":"xy","color_options":{"execute_if_off":true},"last_seen":"2024-07-11T13:33:43+02:00","linkquality":196,"power_on_behavior":"on","state":"OFF","update":{"installed_version":50331664,"latest_version":50331681,"state":"available"},"update_available":null}'
[2024-07-11 13:33:44] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/response/device/ota_update/check', payload '{"data":{"id":"Keller Lampe 1","updateAvailable":true},"status":"ok","transaction":"izs9s-1"}'
Logs for LED2107C4:
[2024-07-11 13:52:20] info: z2m:mqtt: MQTT publish: topic 'fkg/Schlafzimmer Nachtkästchenlampe rechts', payload '{"action":"off","brightness":1,"color_mode":"color_temp","color_options":null,"color_temp":370,"last_seen":"2024-07-11T13:52:20+02:00","linkquality":144,"power_on_behavior":"on","state":"OFF","update":{"installed_version":50331664,"latest_version":50331681,"state":"available"},"update_available":null}'
