Osyris
1
Bonjour, j’ai un avertissemrnt de configuration de mon fichier yaml
Avant que cela ne fonctionne, plus, pouvez vous me dire ce que j’ai fait de mal ? Mon yaml n’est pas trop gros
default_config:
http:
ssl_key: /ssl/privkey.pem
frontend:
script: !include scripts.yaml
scene: !include scenes.yaml
cover:
- platform: group
- cover.chambre_kevin
- cover.chambre_lea
- cover.chambre_parents
- platform: group
- cover.bureau
- cover.cuisine
- cover.salon
- cover.salle_de_jeux
mqtt:
- button:
unique_id: envoi_msg_esp8266
name: "Envoi message ESP8266"
command_topic: "esp8266/distrib/1"
payload_press: "Envoyer"
availability:
- topic: "esp8266/distrib/1"
qos: 0
retain: false
entity_category: "config"
device_class: "restart"
- sensor:
unit_of_measurement: "H"
state_topic: "esp8266/derHeure"
sensor: !include sensors.yaml
Renseigner votre problème
version |
core-2023.9.3 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.11.5 |
os_name |
Linux |
os_version |
6.1.21-v8 |
arch |
aarch64 |
timezone |
Europe/Paris |
config_dir |
/config |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
GitHub API Calls Remaining |
5000 |
Installed Version |
1.33.0 |
Stage |
running |
Available Repositories |
1294 |
Downloaded Repositories |
13 |
logged_in |
false |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 10.5 |
update_channel |
stable |
supervisor_version |
supervisor-2023.09.2 |
agent_version |
1.5.1 |
docker_version |
23.0.6 |
disk_total |
13.9 GB |
disk_used |
7.9 GB |
healthy |
true |
supported |
true |
board |
rpi4-64 |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
Duck DNS (1.15.0), File editor (5.6.0), Terminal & SSH (9.7.1), tydom2mqtt (3.4.1), Mosquitto broker (6.3.1), ESPHome (2023.9.1), go2rtc (1.7.1) |
dashboards |
1 |
resources |
13 |
views |
4 |
mode |
storage |
oldest_recorder_run |
25 septembre 2023 à 10:03 |
current_recorder_run |
29 septembre 2023 à 10:51 |
estimated_db_size |
28.86 MiB |
database_engine |
sqlite |
database_version |
3.41.2 |
Sonoff
version |
3.5.2 (2ad1cd7) |
cloud_online |
1 / 1 |
local_online |
0 / 0 |
Giga77
2
La configuration que tu dois modifié ne se situe pas dans ce fichier.
Regarde dans sensors.yaml
Regarde ça aussi: Résultats de recherche pour « command_line » - Home Assistant Communauté Francophone
Osyris
3
Ok j’ai créer le command_line.yam que j’ai inclus dans configuration.yaml et je n’ai plus l’avertissement.
Merci beaucoup
