Salut à tous,
J’aurais besoin de vos connaissances pour essayer d’adapter un plugin de discourse qui est discourse affiliate pour ajouter la fonction sur les liens Aliexpress.
GitHub - discourse/discourse-affiliate 75
Voici un liens qui peut être posté
Version mobile
https://m.fr.aliexpress.com/wholesale/Ouverture+porte+xiaomi.html?channel=direct&keywords=Ouverture+porte+xiaomi
Version classique
Il peut être simplifiée par
https://aliexpress.com/wholesale/Ouverture+porte+xiaomi.html
Puis avec le tag ajouté. (hacf21)
Voici les explications de Aliexpress
4.How to add custom tracking strings to your affiliate links?
To add custom tracking strings to your affiliate links simply add to a question mark “?” to the end of any affiliate link, followed by the extra parameters.
This is how an affiliate link will look like (WITH custom tracking strings):http://s.click.aliexpress.com/e/abcD12345?af=001&cn=002&cv=003&dp=abc
The components and parameters of this link are:
1.Affiliate link
Your default affiliate link might look link this (this link can be obtained from our portal or via API) http://s.click.aliexpress.com/e/abcD12345
2. Custom tracking strings
You need to add these custom strings at the end of the affiliate link. We will record them and you will be able to see after export from “Live Order Tracking Report”.
af: your unique sub affiliate tracking id. Without “af”, the report will be a cluster of data.
cn: Your unique campaign id
cv: Your creative id, this is for you to identify the banner or textlink or whatever format you’ve chosen for your campaign.
dp: Dynamic parameter. You can customize your tracking characters
The custom tracking strings (af, cn, cv, dp) cannot be changed to different names, but you can choose to use one or two or all of them, based on your tracking needs.
N’hésitez pas si besoin d’informations.
Bien-sûr je suis un peu gourmand, mais vu la formidable équipe.
Si il peut aussi y avoir une fonction automatique sur discord, nous sommes preneurs.
